I can make a 1200 grit edge look like a mirror with the right angle and lighting.. in a photograph..
not in person!
There are no real “mirror” bevels when using under 5K to at least 10K for polishing.. THEN stropping.
Anyone saying they have a “mirror” edge with anything less, is using a definition that does not match mine (nor that of industry, or aerospace metrology). If it is not as bright, and reflective as a bathroom mirror, and has more than 5% of the bevel containing visible scratches, NOT using magnification, I don’t consider it a mirror bevel/edge !!
Reflective, sure! Pretty, absolutely. Photogenic… I can make it that.
A “mirror” edge..
Nope!
Check this thread:
http://wickededgeusa.com/index.php?option=com_kunena&view=topic&catid=6&id=892&limitstart=0&Itemid=271
Back to the ceramics,
Ken said:
[quote]No, the other way:
Curtis said:
MicroFine Coarse –> 1200 —> 1600 –> MicroFine Fine.
[/quote]
That having been said… there is no “NO” when sharpening..
It depends is a better answer.
I have used… when I use the ceramics, 1200, MF coarse, 1600, and MF fine… and have been real happy with the results..
I also have “really” lapped the stones with the DMT XXC, C, and XF diamonds plates…
This will make a big difference for sure. I think that Curtis reported lapping his ceramic stones… using a different set of plates.
The bottom line is, try it and see what you think. That is the ONLY way that you will know what works for YOU..
The MicroFine Ceramic stones have a place in a progression… I know that from using them. Where they fit in your progression… you need to figure out for yourself. Experimentation and the ability to precisely repeat sharpening procedures to define the differences are the strong suite of the WEPS. Take advantage of that, you will amaze yourself with what you learn..
Also, maybe think about whether you are striving to make a blade real sharp, or real pretty, or both.. and what is the priority. I can make a knife real sharp, in 15 minutes. I can make it REAL pretty (what I consider a mirror bevel) and about as sharp, in three to four hours or so (using 20+ different grits where the stones and strops, with abrasives, cost way more than the knives…way more).
I suggest thinking about it and setting your priorities to match your needs…
:woohoo:
