Micro-adjustments Mechanism Questions
I have the PP2 upgrade and I was just wondering how much the micro-adjustment is supposed to move the angle. Should it only alter the angle +/- .05 degrees or is it supposed to allow for more?
The reason I ask is mine used to allow up to a +/- .40 degree adjustment; but now it seems to have tightened up and I don’t know if it’s working as intended or if I got gunk in it.
I’ve been using the soapy sponge trick to keep the steel dust down and it may have gotten into the works on the micro-adjustment screws. Is it possible to take it apart and clean it? If there are any video tutorials out there anyone is aware of, please let me know. I was not able to find one.
Thank you.
Okay, I think I figured it out. Cleaned out the gunk and sprayed it all down with some Tuff Glide and now it seems much more agreeable.
Lovin’ my Wicked Edge!
