I seem to be having an issue with my new ball joint arms. I can’t get the micro adjustment to turn. Do I use the screw knob above the macro adjustment or the tool on the side of the arm slide? I don’t want to mess anything up. In the meantime I’ll just use the regular arms. If someone could shed some light it would be very much appreciated. Thank you!
sunny
Nevermind. I used a different wrench and popped her good. False alarm!
Bill,
i was able to break it free using a hex from a keybar type set. I still decided to use the weps in its original form. (Standard arms, no riser, markers) I figured as I’m breaking the stones in I might as save the good stuff! Some hiccups here and there but overall very pleased!
sunny
