I’ve got 4 - 6 weeks left of the quoted lead time (the wait is killing me). Does WEPS meet their lead times usually? I ordered the Gen 3 without the shelves but opted for it mounted on granite. What should be the first things I should do upon receiving my WEPS? What items if any should I purchase before it arrives (eraser, storage container, etc.).
If you haven’t already, read some of the tips on the instruction page https://www.wickededgeusa.com/instructions/ In particular, ‘How to Find Your Angle’, and ‘Finding the Sweet Spot’… these seem to be the most needed for new users, (and often overlooked 'cause they can be hard to find). Also there is a FAQ page with good info https://www.wickededgeusa.com/category/faqs/
Not sure if W.E. meets their deadline… can’t help there. I would hold off getting anything else… you’ll definitely get enough to get you well on your way… then decide what else you may need as far as storage, etc… kinda depends on what you’re setup is going to be… for example will you have a permanent station, or have to pack everything away after sharpening.
In my case they delivered in a bit over 4 weeks. As for what else to get - it depends on your setup and sharpening needs. IMHO storage is important. Some miscellaneous things like a couple of spray bottles for water and isopropyl alcohol. Masking tape, perhaps. If you also ordered water stones, you might need to get a couple of lapping plates. For my Japanese kitchen knives I needed to get a low angle adapter with an angle cube. Compressed air to clean your station after you’re done
If you’re getting the micro-adjust arms, big for me is an inspection device. A lot of new users are befuddled because they can’t seem to get their knives are sharp as they expected. The problem is that they can’t see that they’re not hitting the right angles. dima suggests a magnifying glass. I’d suggest a good 10X or better loupe. When you get more serious, think about a USB microscope, if you have a laptop handy. Being able to see angular errors of one or two tenths of a degree is a huge advantage when you get into the higher grits.
I actually don’t like it on the Iphone but it does work.. It seems to be much better on the Ipad. I am not really sure why. I have a Iphone 5S (Still) and a Ipad Air (5th Generation) and that may be why. I think the pictures are great for the cost of the device. When I get a opportunity I will take some photos and post them here. I haven’t used it much since I started playing with my USB microscope. However, at trade shows or at a sharpening booth it’s perfect. The USB scope is just easier to use but they both play very different roles while sharpening. I find because it is so small, I keep losing it LOL. But for the money, It’s great all around.
