Yeah, there is no real transition in this knife that you can see, it is full flat with a hint of a convex taper to true zero and then there is a micro-bevel applied. It was hand sharpened by the maker hence you can see multiple layers of scratch patterns.
With the destressing, some people get really focused on wasting the metal and are opposed to doing the initial cuts into the stone because it grinds off steel which could have been used. The problem is though is that steel is in a very stressed state and is thus very weak and it also is going to be carbide depleted due to tear out and fracture. If you form an edge on that then the edge retention and durability will suffer.
To me this is self-defeating because which would you rather use :
-a knife in 154CM, S30V, m390 etc. where the edge is always stressed
-a knife in 420J2 where the edge is always formed on clean steel
The first knife will actually have less edge retention/durability than the second one so what exactly did you pay more money for that “upgrade” steel if sharpening it properly wears it out too fast for you and to compensate you have to leave the steel weakened so the performance is lower than if you went for a lower cost steel in the first place?
For me one of the most dramatic experiments was one I did on a Battle Mistress were Busse asked me how many 2x4’s worth of wood could I chop before sharpening (if I stropped). I cut over a 1000 with no real problems but suddenly the edge started to take visible damage on the wood which it had not in years of previous use. I then repeated this (more than once) and sharpened the knife instead of stropping and the damage never happened again.
Even with a lot of sharpening, as long as you are not spastic about it, a knife will last a long time. If you are using a system like Clay’s where you can exactly set bevels and minimize over grinding then I really see it as a moot point. For me accidental damage is what limits the lifetime of the knife, never sharpening.
I have knives which are literally generations old and still used. I sharpened a knife for a friend recently which was given to her from her grandfather and he got it from his parents and it wasn’t new to them. She won’t use it out and neither will her children.
Remember when you destress the edge it is only going to be about 50 microns wide as you just want to be able to see it. Depending on angle, this means that 20 full sharpenings will remove a mm of metal from the width of a blade. For kitchen knives for friends I sharpen them at most twice a year, this means in 10 years they have lost 1 mm of metal from the width. Most people lose knives before they actually wear them out.
