i have been having the same problem also.
From videos I’ve seen of WEPS users in action, I think that many use the vise improperly, and it can lead to problems like a bent jaw, gouged pockets where the jack screw turns against the lower end of the movable jaw and damaged threads with the upper clamping screw.
When I was on the early slope of my learning curve (yes, I’m still climbing) I was amazed at the clamping power of the vise assembly, so I sat and cogitated on the cleverness of the design, and realized there were reasons for how it was designed. Kudos to the mechanical engineer who designed this doodad. It uses a lot of commonly known principles, but they are very well applied. Clay – was that you?
I soon began to notice that some users were over-tightening the screws unnecessarily. The upper screw thread needn’t (shouldn’t) be turned under a heavy load. It only needs to set the distance between the jaws at the bottom edge of the blade. The lower screw has a tremendous mechanical advantage in producing clamping force and usually needs to be turned only 1/4 to 1/2 turn past contact. If we completely disregard friction, a ten inch-pound twist on the screw would apply 1256 pounds of force to the movable jaw’s lower jack screw contact point. Then there’s the lever principle amplifying the force across the fulcrum of the upper screw to the clamp point above. Producing what? A hypothetical 4,000 lbs? Does somebody have a load cell to measure the actual force?
I lube my screws with a grease which has anti-seize properties. I also took my lower screw out and ground a smooth flat on the end so as to reduce scoring at the contact point. Ideally, you’d have a brass pocket thrust washer between the screw and the jaw face.
Certainly, longer knives need more clamping force than shorter knives, but if you need to apply a lot of force on your vise’s lower (or upper screw) screw to achieve the needed clamp force, ask yourself why. Is the blade very long and easily moved by applying force out at the ends? Is the cross-section of the blade such that the vise is only clamping a very small area? Is it mounted as low in the vise as possible? On another topic in this forum (http://wickededgeusa.com/index.php?option=com_kunena&view=topic&catid=2&id=12761&Itemid=271#15350), I recently demonstrated that you can use shim stock to securely lock a non-flat blade in place. In my test, adding small pieces of shim stock at the upper end of the jaws made a huge difference in how solidly the blade was held. My test case was intended to eliminate vertical rotation of the blade, but the blade was clearly more securely held. In another test I tried, I used a very small strip of 150-grit abrasive fabric from a drum sander to both hold a blade more securely, but also to shim the blade into a more upright position.
If the blade is wide enough, it would be better to lower the blade in the vise - lower than the lower position of the depth key. This would move the point of highest clamping force closer to the fulcrum and farther away from the tip of the jaw, which is the weakest section in terms of bending moment.
Certainly, changing the jaw material to tool-steel or titanium would reduce the chance of bending jaws. That said, the strength of the aluminum alloy jaws is incredible. Should there be an industrial model?
And this is for Clay (or his associates):
Is there a way to “unbend” the jaws? Would you have to over-bend the jaw to achieve full return to form? How about using a hydraulic press to force a bent jaw into a wedge-shaped pocket in a steel fixture? Can it be done without fatiguing the material? Or are the jaws inexpensive enough to make my writing just a bunch of annoying noise.
This is what I just did. Its working well so far. Machine shop wanted $750 to make something similar.
The first photo looks really interesting. Can you give us a straight-on view? What’s the total height? What angle range are you getting?
Hey tc, after staring at your questions for awhile and thinking of what to write i think the appropriate answer would be that its just something kind of cool i made and i wanted to share. W.E. has everything needed to obtain just about any angle needed. I did just get another cool idea while i was looking at this and if i get around to making it maybe ill share that too. Thanks
Thanks Dan. A friend, Devin, and I designed the clamp.
[quote]
I soon began to notice that some users were over-tightening the screws unnecessarily. The upper screw thread needn’t (shouldn’t) be turned under a heavy load. It only needs to set the distance between the jaws at the bottom edge of the blade.[/quote]
Exactly!
[quote]
The lower screw has a tremendous mechanical advantage in producing clamping force and usually needs to be turned only 1/4 to 1/2 turn past contact. If we completely disregard friction, a ten inch-pound twist on the screw would apply 1256 pounds of force to the movable jaw’s lower jack screw contact point. Then there’s the lever principle amplifying the force across the fulcrum of the upper screw to the clamp point above. Producing what? A hypothetical 4,000 lbs? Does somebody have a load cell to measure the actual force?[/quote]
I’ve been meaning to get this done at one of the labs around here, haven’t gotten to it yet.
[quote]
I lube my screws with a grease which has anti-seize properties. I also took my lower screw out and ground a smooth flat on the end so as to reduce scoring at the contact point. Ideally, you’d have a brass pocket thrust washer between the screw and the jaw face.[/quote]
The new jaws have a steel puck as a kick plate for the jack screw.
[quote]
Certainly, changing the jaw material to tool-steel or titanium would reduce the chance of bending jaws. That said, the strength of the aluminum alloy jaws is incredible. Should there be an industrial model?[/quote]
I’ve had a set made in steel. They are very strong but there is not much friction between the jaws and the blade so the blade actually slips around more easily unless you use another material in between.
[quote]
Is there a way to “unbend” the jaws? Would you have to over-bend the jaw to achieve full return to form? How about using a hydraulic press to force a bent jaw into a wedge-shaped pocket in a steel fixture? Can it be done without fatiguing the material? Or are the jaws inexpensive enough to make my writing just a bunch of annoying noise.[/quote]
We had a jig built a while back, maybe 4 years to bend the jaws back into shape. It works reasonably well but is time consuming. You do have to over-bend them to get them back to straight and we speculate that some ‘work hardening’ occurs that ultimately makes them more susceptible to fracturing.
Really? I had mine made out of tool steel and I have never had a problem… I do make sure that they are tightened down real well though!
Actually, it’s Tom, not Dan, but TC works just fine. Thanks much for your replies.
Hard steels would have a problem clamping similarly hard material. Imagine trying to clamp a piece of plate glass between a pair of flat, polished granite jaws. You have to have at least some “bite” to hold position. I was going to suggest that a tool steel vise should have brass jaws, even if they’re very thin.
I have electrical heat shrink tubing on mine I would think it would work equally well on steel jaws.
This stuff?
http://www.aliexpress.com/item-img/Air-dry-heating-element-tube-finned-heat-pipe-heat-sink-heat-pipe-oven-electrically-heated-tube/551245966.html
This stuff.
No it looks a bit like a sort of plasticised bike inner tube it comes in all sorts of sizes and colours it is often put on the ends of car battery cables where the wire is crimped onto the connection loops most electrical places sell it from sizes suitable for 2/3mm wire up to quite large circumferences where many wires are held together the tube is placed over the cable of lets be more specific and then shrunk with a heat gun .
Since the WE vice tapers it is removable but it works very well better than self amalgamating tape since it need not be thick it seems to work well . Some other WE owner had done it I saw last June it looks smart and if you use the black it is almost invisible .
The tubing for the WE vice should be around 3.50€ a metre you will find it in an electrical/electronic component shop.
It was your vice that I saw it works really well very tidy. I seem to remember you did some smart styling on the base polishing off the blue anodisation if I recall correctly.
Yes i stopped posting when the web site was hacked.
Can you post a pic of your storage box. I like the tubes you are storing the stones in.
I came on this thread to attest to Wicked Edge customer service. Having noticed my clamps were bent, I called customer service and, with no questions asked, they replaced my clamps. Very professional, this is a company that stands behind it’s products, even in a area like these clamps that could be bent by overzealous use.
[quote quote=“Wes74” post=15838]Can you post a pic of your storage box. I like the tubes you are storing the stones in.[/quote]
we have been using this stuff for quite some time on our scoop handles - works great.
can be bought at most high end electronic shops or ebay - many colors available.
http://www.intertexelectronics.com/HST-1-12-Heat-Shrink-Tubing-1-12-x-4ft-Polyolefin-21--P2109.aspx
