How Small a Knife Can You Sharpen? - Examples
here is a small wood marking knife from the show today - chisel grind at 22 degrees (just matched the angle on the edge, I actually started at 18 as that is what he thought was on the knife, missed the clamp but not the shoulder!). didn’t do any other measurements…
View photo here - can’t get to link into post - Mark or Curtis can you help??
interesting Tormek Clamp- thanks for putting it up Curtis. I look forward to seeing more info on how it works for people…
Like Tom I see a lot of small knives like his victorinox at shows - I do have a few pics from older shows but no details. I’ll try to get those up
[quote quote=“BobNash” interesting Tormek Clamp- thanks for putting it up Curtis. I look forward to seeing more info on how it works for people…[/quote]
Just got mine yesterday. Only did one knife so far? Seems like it is going to be a nice addition to the WEPS. Tried mounting it a couple different ways to check angles? I was able to put a 20* per side on a little Case my friend has and it was sharp when I was done!
Gee whiz, Bob. I thought MY clamp was worn down from trying to go too low :wink:
Ken
I’ll just add the photo…
Facebook photos… so I can tell people they should check out your , where you have a ton of pictures! :woohoo: :woohoo:
This was the first knife i sharpened for some one else. A double bladed buck 303. What a pain it was. The other blade was shorter but the same height.
Funny after reading about the Tormek small knife Jig I thought I would finally get one as yet I await my WE but I do have a Tormek
I do not like the knife Jigs on the Tormek they are quite difficult to use properly and adding this small knife jig just makes it feel even more ungainly it also feels as if the whole thing is flexing.
I think it will probable work and feel a lot better on the WE.
I could not upload the image of it still if you look at it set up on the Tormek it is cumbersome and it is difficult to do a low angle so for a Tormek it is not a lot of use.
I got one of the Tormek small knife jigs. At first I thought I really liked it on the WEPS? But as time goes on I find myself never using it and just doing the small knifes on my bench stones. The friends that I sharpen for don’t really care if their 1" blades have a sub micron edge. I clean them up on a Arkansas stone, strop and be done with them. :stuck_out_tongue:
[quote quote=“LeoBarr” post=12704]Funny after reading about the Tormek small knife Jig I thought I would finally get one as yet I await my WE but I do have a Tormek
I could not upload the image of it still if you look at it set up on the Tormek it is cumbersome and it is difficult to do a low angle so for a Tormek it is not a lot of use.[/quote]
I actually do think it works better on the Wicked Edge than the Tormek, but (and don’t take this the wrong way) did you read on how to set it up on the Tormek? I didn’t… and I set it up wrong, and had the same issues you’re describing, which is why I wondered. Set up right it works better (imagine that haha)… and I could pretty much hit 0 deg. if I wanted.
But yea, it works pretty cool on the WE… and you don’t have to save it for small 1" blades, but for blades you may want to hit a “lower than normal” angle on.
Perhaps I should check the instructions again !!
I am beginning to get a feel for the Tormek which I use chiefly to repair blade geometry or to remove knackered serrations which I do freehand I find the knife jigs feel clumsy I do however like the chisel jig which is probable the best jig I have.
Probable the most amazing jig they do is for sharpening drill bits but you would need to sharpen loads to justify the couple of hundred Euros that jig costs.
The small knife Tormek jig used on the WE could be interesting for low angle bevels still I patiently await my WE to try it out.
Would the riser and arms of the Pro Pack 2 upgrade be able to allow shallower angles on a smaller blade? On a GEC’s pen knife, the lowest it can go is about 20-21, and was hoping the riser would help bring it below 19 without completely grinding off the corners of the clamps.
I’m thinking it wouldn’t help much, since the clamp itself is in the same spot relative to the blade, at which point I was looking at the other clamp option, the low angle adapter.
I’d rather not buy both of them for the sake of trying, but I have some SAK blades I’d like to do at a shallower angle, primarily the pruner and electrician blades.
[quote quote=“sticktodrum” post=14581]Would the riser and arms of the Pro Pack 2 upgrade be able to allow shallower angles on a smaller blade? On a GEC’s pen knife, the lowest it can go is about 20-21, and was hoping the riser would help bring it below 19 without completely grinding off the corners of the clamps.
I’d rather not buy both of them for the sake of trying, but I have some SAK blades I’d like to do at a shallower angle, primarily the pruner and electrician blades.[/quote]
Just quoting for a bump. Anyone have some advice? :slight_smile:
Sure. If you want lower angles, go for the Low Angle Adapter.
You also might want to take a look at Tormek’s Small Knife Adapter that I mentioned in the first page of this thread.
Small Swiss army knife-pp2
You can sharpen down to 14.5dps /strop at 12.5dps if wanted.
Homemade, i still have to shave a bit off to get to the heel and paint it to look kinda cool. I like it over my tormek small knife holder already. :
No handle compression or rotation.
[quote quote=“DanMaloon” post=18034]Small Swiss army knife-pp2
[/quote]
Dan, what is that accessory you are using? That’s great! Wonderful innovation
Thanks man, thats my fly making vise! Haha. Just kidding
Shoot me a pm Josh if you want ill make you one
I’ll buy one too. Please.
Sure jim, im taking off soon until the end of july. Ill start when i get back. If anyone wants one or one those scissor clamps just pm me and ill get back to you.
pm sent!
Alright. Ill start when i get back. In the meantime what do you guys think of something like this to free up the handspace/movement for straights? Gets to 4.5dps. Painted black just to look cool haha -dont mind tthe actual " razor" or screws
