Nope, you still have two legs… and a chest to work on..
:lol:
I like the enthusiasm.. but take your time.
Keep it coming.
Phil[/quote]
I didn’t want to mention that both legs and chest are now bare… :huh:
Probably the most amazing thing I saw was how the blade really shined when I used the Micro Fine Ceramics. The real test will be with the loupe but I bet it won’t look nearly as good under the microscope.
So tonight I sharpened four blades. All went OK (still learning) except a fixed SOG knife. This knife has temporarily kicked my ass.
The SOG blade is tapered and does not have a flat place to mount it in the Wicked Edge base. For this reason, no matter how I tried to mount it, it was not mounted as tightly as it should have been. I started over three times from 100 grit to strops and it just is like it should be…
The only thing I can think is that the knife moves in the base slightly because of the tapered blade making the base only hold the blade on the very edge. Actually, I have to sight the blade while working it as it moves slightly. I wish my loupe was here so I could actually see what I’m doing.
Is there a way to clamp this type of blade up in the WEPS? I had to stop for the night…
Craig,
I use “electrical friction tape” on all my knives, it really locks and holds the knife in the vice with no residue and no over tightening. Another thing and I know it won’t help with the SOG but with folders, especially those with heavy handles is I fold the handle up 90 degrees so I don’t have all that weight of the handle hanging out there.
Chet
[quote quote=“ChetParks” post=9762]Craig,
Chet[/quote]
I have read about using friction tape. I will give it a try. I’ve not had any issues with this until I tried to sharpen a blade with a full taper and no flat areas to grab.
[quote quote=“cbwx34” post=9763][quote quote=“CraigDavis” post=9760]The SOG blade is tapered and does not have a flat place to mount it in the Wicked Edge base…
Is there a way to clamp this type of blade up in the WEPS?[/quote]
Sharpening a Full Flat Ground BladeHave you seen the page?
In addition to Chet’s idea, I use a thin piece of leather to hold some blades, others have recently said using a piece of Moleskin works well.[/quote]
I have not seen the Full Flat Ground Blade page. Guess what I will be reading…
[quote quote=“CraigDavis” post=9769]'ve not had any issues with this until I tried to sharpen a blade with a full taper and no flat areas to grab.
Thanks for taking the time to help.
Craig[/quote]
I just sharpened 4 railroad spike knives that a guy sent in. They are very thick and have a radical taper, both from spine to edge and heel to tip - absolutely nothing close to parallel on those blades. I used friction tape on them and it worked great. The heel-to-tip taper was so pronounced that I had to put an extra piece of tape, folded up on the far half of each jaw to fill in the extra space. Once I did that, they knives locked in very solidly.
Any idea what the quality of the steel is like in the railroad spike knives? I’ve heard both good and bad about them… never handled one in person though.
Any idea what the quality of the steel is like in the railroad spike knives? I’ve heard both good and bad about them… never handled one in person though.[/quote]
The steel isn’t super hard though I think it’s fairly tough. I’ll have to do some investigating to see what can be learned about them.
So tonight I did a (very) slight reprofile on my NIB BM Barrage. I can say that it now has a Wicked Edge and M390 is absolutely no match for my new toy.
Disassembled the Barrage and the blade is going off for heat treat.
Yeah, it’s funny when I read on other forums how much trouble people have sharpening these new steels like M390 or ZDP-189. I note little difference with many other harder stainless steels. The diamond stones still go through them like butter and even the medium (ceramic) stones work fine. Only if I want to go further and I’m not out for a mirror finish, I prefer Shaptons over Choseras.
The diamond stones still go through them like butter and even the medium (ceramic) stones work fine.[/quote]
Strage, when I use the diamonds they go through steel like … well Steel.:silly:
Maybe I am doing something wrong???
Why do you prefer the Shaptons. I have heard arguments on both sides of this, but I am curious as to your reasons.
I only have the Shapton stones in 5K and 15K. I have had them for about 8 months and used them exactly 4 times. Obviously I am not that impressed with them. Of course I am a creature of habit … and tend to go back to what seems to work well for me. I did not find that the Shaptons cut any faster, or produced a sharper edge, but they do leave a scratchy bevel (even at 15K which is listed as having a finer abrasive than the 10K Chosera).
I would be interested in trying the Shapton 30K some day, but the cost/benefit ratio is not really there for me at this time.
It does. But even more you can get a great view of the edge of the edge. Sometimes, even after I think I’ve apexed, once I go down a couple grits, I can see a thin line where I’m not actually quite there… Back up, go forward
