Yeah, I have the screws loosen almost constantly unless I really torque them down as tight as I can with finger pressure. I tend to check the screws in between grits or between “sets” of strop strokes. The left side likes to get loosey goosey all the time, the right not so much.
I’m constantly fiddling with the strop angle, and definitely noticed an immediate difference in the feel of the edge. Cuts great either way, but strangely the reduced angle “feels” less sharp despite probably cutting better. Definitely a curious phenomenon, and probably why I’m always fiddling with different settings
I also sometimes use Clay’s trick of slightly wetting down the leather. I might try -1 degree and dampening the leather this evening on my carry knife, to compare to the finish it has now.
Guessing you’re right handed. =P Mine, the right side loosens more often, but I’m a lefty, so I’m guessing I am able to tighten the left a bit more than the right.
Kinda wish there was some better method than the thumbscrews.
[quote quote=“ApexGS” post=5675]Yeah, I have the screws loosen almost constantly unless I really torque them down as tight as I can with finger pressure. I tend to check the screws in between grits or between “sets” of strop strokes. The left side likes to get loosey goosey all the time, the right not so much.
I also sometimes use Clay’s trick of slightly wetting down the leather. I might try -1 degree and dampening the leather this evening on my carry knife, to compare to the finish it has now.[/quote]
I remember seeing something about wetting the leathers but don’t remember what solution was used. What is the preferred solution and technique does one use?
