Clamping a Spyderco Techno
There’s a bit of flat surface area above the Spydie-hole on this ffg blade. I’m wondering where you gents would clamp this knife on your WEPS.
Thanks in advance!
clamp it as close to the scales as you can… I would use the “clamp and tilt” method for that one.
A buddy told me bottom holes, position B… But it just doesn’t seem that cut-n-dry to me.
Josh!
Also, we’re looking at about .25" stock of CTS-XHP. So, what dps are you suggesting?
I NEVER and I mean never use the depth key adjustment anymore lol… not since I have an angle cube, an angle cube allows me to get almost the exact same angle every time.
I would simply go up through the 1k grit edge, leave it at 15 dps w/ no micro bevel. Should be more than stable at that angle.
Maybe this video will help if you haven’t seen it already (although I think you have??)
http://www.youtube.com/watch?v=2T0wQDHKMR0
I agree with Josh’s thinking…clamp and tilt. Doubt I’d use the bottom holes though. I’d probably try to match the factory angles or close to it.
[quote quote=“razoredgeknives” post=21150]Maybe this video will help if you haven’t seen it already (although I think you have??)
http://www.youtube.com/watch?v=2T0wQDHKMR0[/quote]
Yes sir. Seen it about a dozen times :slight_smile:
I’ll let you know how it all goes down and post some pics later this afternoon when I get off work.
Thanks for the advice! You rawk like a hurricane!
This is exactly what I did with a manix…worked perfectly…thanks Josh for the video on this one.
