Just curious. Did you look at the links in my last post. The videos you posted are done by Tom B, as were the blog posts that I linked. He has more detail in the blog posts. Take a read of them when you have time…
“I am still curious if someone can address the question of which set of the Chosera waterstones fit best in between the 1000 diamond stones and the micro fine ceramic. This is especially relevant in light of your comments regarding the grit measure not reflecting the actual results in real life.”
I hope that you get something on this. Not sure how many are using the Ceramics and the Choseras. I can’t directly answer it, as I have none of the ceramics. I plan to remedy that soon. I plan on talking to Kyle about it in the morning.
I would think that Clay feels like the super fine ceramics fill the gap. Only by guessing would I say that the 800/1000 and the 2000/3000 would get you there nicely. The 5000 is a nice stone, but I often skip it and the 10K for a great useable, resonably agressive and still real pretty edge. I am not sure what adding the microfiine ceramics to that progression will do as far as the mirror edge is concerned. Possibly dull it (not the edge, the shine), as the Choseras are great polishers, even in the coarser grits. By grit size, you could get some edge refinement, but stropping can get you there as well.
It is all so complicated
:evil:
Don’t obsess about getting a progression that covers every 500 or 1000, or even a few thousand grit sizes. There are lots of folks that will tell you going from a 1000 grit Norton to an 8000 grit is just fine.
Results is what you really want, not engineering continuity…
I was exactly where you are with the WEPS a couple of years ago. I bought stones in pursuit of the goal of absolute grit continuity that I seldom use “in real life” these days. I read Tom taling about the Shaptons, so I had to have some of them, only to find that they made things really sharp, but left more scratches… Damn, what do I really want??
I will see if I can find some of the external threads where people swear that 600 grit and stropping is the absolute best way to go. Check the sharpening DB here. You will be amazed at how many stop with the 1000 grit diamonds… and maybe a bit of stropping.
I know well that is not what you want to hear…
Been there, done that!
Keep in mind something I said before… basically, You will never know until you try… I didn’t!
Buy them all !! You won’t be happy until you do.
