Just to be clear, I’ve only used the glass media once - in the case of the longitudinal cluster. I think that a break-in procedure using glass might be a workable method, but would need to be tested by someone who had a lot of new stones they could afford to throw away, or were willing to put at risk. I believe that a result might be that some low number of strokes on glass would work as well as 10 to 20 knives. I don’t know if that number is 10 or 50. Maybe Clay could try that out while checking the surface of the diamonds with his 2000X microscope. The objective is to knock off all diamond particles not directly attached to the platen. At what point is that accomplished?
I am thinking that WE’s supplier has been improving their process, as the last set of stones I bought (400/600 and 800/1000) worked beautifully from the start. Yes, they feel a lot coarser than my well-used stones, but there were none of the “clunks” I’ve felt in the past, when the first few sharpenings were really rough.
