Busse HHFSH Beautified
Hello All,
I thought it was time to take two of my Busse Knife edges to the next level. The one I’m most proud of is my Busse HHFSH – easily one of the best fixed blade knives I’ve handled for a Jack of All Trades Knife. Check it out:
-Rob Abyane
Wow, again someone who confines his Busse to printer paper :stuck_out_tongue: .
Just kidding, very nice work!
Wow. Beautiful. Very nice!
Very nice! Did you do any reprofiling at all? I just recently reprofiled a 7-8" bladed Al Mar to 10 dps on the Wicked Edge and it was NO FUN lol, took a LONG time.
[quote quote=“mark76” post=23540]Wow, again someone who confines his Busse to printer paper :stuck_out_tongue: .
Just kidding, very nice work![/quote]
No restrictions at all – my Busse knives cut air, cut paper, cardboard, furniture, Christmas trees, wooden palettes, and a variety of different wood type trees. No discrimination around these parts
Thanks!
Hey Josh – I reprofiled the edge to 19 - 19.5 degrees. Some parts of the factory edge we’re close to 25+ degrees. It really did take long. I only have 100/200’s
Oh wow – I’m not aware of the starting edge angle on the Al Mar nor the steel – but reprofiling down to 10 degrees sounds like A LOT of work. However, I’ve noticed that the edges I get with a belt grinder – even ones that use a stropping belt – they don’t come out as sharp. I mean – for me – the difference is very noticeable. Sure the blades can push cut paper after using a belt grinder – but they’re not as pretty and definitely not as precise. Just my 2 cents of course.
I will say though – that I still need to learn to effectively master recurves. I find that I keep missing small spots that require me to go back to correct.
-Rob Abyane
Yeah, it is ridiculous how much time it takes. I normally do the heavy reprofiling on my belt sander then come in and micro bevel on my wicked edge, but this customer wants it all done by hand. :ohmy: :dry: Right now I am working on a cold steel double edged dagger for him… So far it has taken me about 30 minutes to reprofile the front half of one side (i.e., 1/4 of what I need to sharpen) and has taken 1200 scrubbing passes per side with newly broken in stones… and I’m only going to 15 dps on this one :whistle:
Josh:
What was the problem that drove you to use the Tormek adapter? FFG? Fear of damaging the blade?
I’ve never used the Tormek for anything larger than a Swiss Army knife. Is it that solid? Of course, it must be or you wouldn’t be using it. Wow. That’s really impressive.
Tom.
[quote quote=“tcmeyer” post=23553]Josh:
Tom.[/quote]
Neither, hehe. I used it because I wanted low angles at 15 dps and the vise would get in the way if I clamped it to the middle grind line portion at the heel of the blade on the flat… this way there is no issue. I used the tormek jig also on the 7" al mar I recently did, which got it to 10 dps no problem.
