That’s good information, just purchased my Pro Pack 2 last week, getting great results so far!
Good to hear, and welcome to the forum! ![]()
I agree about the fine diamond hones. I don’t have the EEF DMT, but have bought some “other” brand fine and extra fine plates. They wore to uselessness faster then I had hoped. In places the diamonds are just gone now.
I have wanted to try the DMT EEF , hoping their coating process was better. Maybe it is, but apparently not that much better…from your results anyway. The EF that I have has been OK, but I tried using it for texturing stones after lapping. That tore it up pretty quickly, so I gave up on that.
I keep thinking about trying the Atoma diamond plates, but the cost versus the amount I would use them has kept me away.
I think I will buy a set anyway, just to see what they do for me…
[quote quote=“wickededge” post=11181]
Funny you should mention those particular stones just now. Today I placed our first order for those stones fitted to our handles. Just need to wait about six weeks now.[/quote]
What grits will it be per handle? And is that an order for internal testing / evaluation or is it for selling?
I had come to that conclusion at one point but I think the 1200 ceramic stone still gets the 1000 grit diamond scratches out faster than the micro fine. And my microfine stones are quite a bit newer than the fine as they were back ordered.
I ordered the 800/1000 Chosera and the 2000/3000 Chosera stones yesterday, do you think there is any reason to get the courser Chosera stones if I have the diamond stones through1000. I mean any difference in end result changing to Chosera at 400 as opposed to after the 1000 diamond?
I would give what you ordered a try and see what you think.
At most it is about speed. Sometimes I go back to the 400 and work up. More often to the 600. Sometime I go from the 1K diamonds to the 1K Chosera stones… Depends on the steel and what I am looking for in the final result… and maybe how much time I have to spend on a blade. It is a matter of how quickly you want to replace the diamond scratches with Chosera scratches.
You may well be happy with what you have coming. Give it a shot.
I’m not through the thread yet, but spotted this and thought I could comment – maybe even intelligently! ![]()
[quote quote=“PhilipPasteur” post=11178]DMT Extra fine is rated 1200 grit.. I think the Extra Extra fine is 8000 grit
They are not cheap, but it seems that that grit level can be made in diamond plates.
No idea whether the supplier that WEPS uses can do those grits.
Thanks Geo!
[quote quote=“MattCole” post=11171]That’s the kit I got too. That is an impossible step from 1000 diamond to the microfine ceramic stones.
And I agree a 1200/1600 diamond stone would be great, I like the consistency of the diamond stones. It’s easy to step up through the grits and get all the last grits scratches out. But there probably is a reason they don’t exist.[/quote][/quote]
The DMT EEF can be had for just south of $15.00 for a 4.3 x 0.9 x 0.2 inches sample. I use “Permanent” double-sided tape, sticky enough to hold the stone tightly in place, not too sticky to keep you from getting it off. The only issue is that you have to remove the platen from the handle – just six screws. But this gives you a good chance to test without a massive investment.
I personally found it too abrasive, even though it’s rated at about 3 micron vs. the 1000 stone’s 7 micron. I’m sure it needs a break-in period, but I didn’t like it enough to keep it. More anecdotal evidence that no two microns are the same. ![]()
this post!Update: I typed the above even before reading ![]()
I also thought I should share my experience with the 3M Micro Abrasive Film/Paper (aka PSA). Here’s my source for the 3M PSA paper.
I like the 3M PSA because it was inexpensive and was easy to use. I had no problems taping it onto the 800 or 1K stones, as the backing is very adhesive. I have used the 5u, 1u and 0.3u Aluminum Oxide. After I gained some experience with them, I noticed a slightly hazy look to my finish, rather than a nice shiny mirror.
I changed to using just the 5u AlOx (site above sells on Silicon Carbide in 5u), and subsequently jumping to strops/pastes (same micron progression) from there. This performed better than the 5 to .3 all-PSA progression, AND better than the 5 to .25 all-strop/diamond paste progression! I had a more noticeable mirror from the 5u AlOx PSA to 3.5u-1u-.25u diamond-on-balsa.
I have not used ceramic on the WE yet, but from descriptions and experience on Lansky/Spyderco, I get the impression the 5u AlOx is acting like a ceramic. I’ve seen ceramic described as “more uniform” and “hazy” in its shine, and this is [exactly how I’d describe the 5u AlOx. I’ve also heard it said that you can get a better mirror by using ceramic prior to stropping – the uniform / hazy scratches aren’t as deep as the diamond, so the strops shine them out nicely. My experience also matches up with that.
The drawback to the paper is that it’s paper. If you have a turned edge, they may (okay, probably will) scratch up before they raise it to vertical. I’ve also scratched them up when the knife tip was turned. Need a stone for that stuff (I only have the 1K and it’s too abrasive for touch-ups like that). But given the PSA’s low cost and total ease of use, I think it’s something worth trying.
-Pie
Pie,
I have seen much the same when using the 3M lapping films. I haven’t done any comparison testing between them and the WEPS ceramic stones.
The big thing that eventually turned me off on them is that they just don’t last. It seems that I was changing them every couple of blades. They are relatively cheap, but if you sharpen enough, within a fairly short period of time…you may as well have bought a set of stones..
BTW, PSA stands for Pressure Sensitive Adhesive.
You can get the 3M films with either plain or PSA backing.
I have been getting the films from Bestsharpeningstones.com. I use the yellow, 12 mic through the white @ .3 in 6 steps total. I bought 3 sets of handles with al blanks from the same site. They last about 3 knives for me but I like that As soon as I get the 1000 diamond scratches out with either 1200 ceramic or the 1.4 mic ceramic, I can go strait to the film progression. Then strop 1 mic down to .125 and have a near perfect mirrored edge with no visible scratches, to the naked eye.
By the way, it is still quite a battle to get those 1000 grit diamond scratches out although I discovered yesterday that it can be done with the 1.4 mic. Micro fine ceramic stones.
The only way I can end up with no visible scratches is to alternate between up and down motions and hilt to tip motions to be sure I have ALL the previous grits scratches out, at least up to the films. Does anyone else do it this way? It seems every time I try to do it all in the same direction, no matter how thurough I think I am being, I end up with a mirror Finish with scattered scratches and scuffs.
I got my basic WEPS from Bestsharpeningstones. I got started with the sandpaper by watching something on you tube.. When the guys tat the above web site hosed my order he gave me two 40 piece assortments of the films.
I got prey good with them. Basically scratch free and pretty reflective. Keep in mind, at that time I was going from the 600 grit diamonds… The 800/1K were not even being made, let alone the microfine or superfine ceramics. I impressed myself.. believe me. I think the finest paste that I had was 3.5 micron WEPS..
Just now I found some blades that I had done that way and compared them to some using the Chosera stones through 10K and the 12K Superstones, then stropping down to 0.025 micron spray on Nano Cloth. No comparison really. The older blades were… hanging hair test passing sharp. No doubt. Some of the later knives were not. Still real darn sharp, hair popping, push cutting phone book paper, sharp (probably the differences in steels)… but the reflectivity of the bevel is an order of magnitude greater. Really, nearly bathroom mirror levels. I mean to the point that when you walk into the room with the knife in the vise…that is the first thing that you see because of all of the light bouncing off of the blade bevel… I am serious.
Maybe I should take a step back one day and prep with up to the 1K diamonds and ceramics, then try the lapping papers. I am curious to see if anything can beat (short of ungodly expensive Japanese naturals) the Chosera 10K.
Yes over the last maybe a year, since I read something Clay said about switching directions cutting the scratches down faster… on the OCD blades, I have been alternating between heel to tip edge trailing and tip to heel edge leading strokes for final polishing.
BTW, you can get full 8.5 X 11 sheets of PSA 3M film in sets from the woodworking link posted above and save quite a bit of money. Sure you have to cut them up.. but lots cheaper than buying the pre-cut film as you have been.
Ya I have been buying full sheets and cutting them down. It is substantially cheaper and I like to have them cut much closer to the size of the blank.
The problem I’m having right now is when I finish with the .3 micron film, the knife is very sharp. But after stropping, 1 and .5 spray on leather then .25 and .125 on kangaroo leather, it’s not as sharp. Much more polished, but really not that sharp.
Has anyone else had this problem? Am I doing something wrong, obviously I am but I don’t see how.
Try reducing your angle by a degree or two when using the leather.
If you are not using whisper light strokes, you may be rounding the edge a bit.
With Kangaroo this should not be an issue, it is thinner and has much less give… but you are using the leather first.
There is a thread where this is discussed. It is also something I believe that Clay said that he does with the leather. I have used the technique… but find using very light strokes usually gets me there.
Okay, thanks. Pretty frustrating to put 4 or 5 hours into a knife only to end up with a beautiful blade that won’t cut paper. I have probably been using too much pressure. They are quite tore up anyway. Is there less of this effect with the balsa stropps?
Balsa does not compress nearly as much as leather… at least in theory they should not cause the effect as much.
Clay has related that he uses quite a bit of pressure when stropping, even to the point of lifting his base up when the strops are treated with alcohol to increase friction. But I he has also talked about decreasing his angles when using the leather.
I find that using light pressure with the finest stropping grits.. letting the abrasive do its job with the least interaction from the media, give me the best results.
One thing you can do after stropping, is return to the finest stone you have (ceramics are great for this) raise the angle a degree or two, and make one or two very light passes on each side of the blade. Try either edge leading or edge trailing, and see what works best for you. Then drop back down and strop just a little bit more if desired, (but not too much). This will often clean up whatever stropping did to the edge that dulled it.
That works, I have done it. Usually I want a bit of “tooth” and this is the goal for me when using this process.
What you do lose is that edge refinement that is really the point (not cosmetics) of working with the finest grit strops.
Better not to cause the problem to begin with!
[quote quote=“PhilipPasteur” post=11262]That works, I have done it. Usually I want a bit of “tooth” and this is the goal for me when using this process.
Better not to cause the problem to begin with![/quote]
In this case I’m not talking about doing enough to really change the edge, only enough to “clear up” whatever the leather did. I’m talking one very light pass… starting at one end of the edge, and moving just enough to get to the other end. It’ll change some, that’s unavoidable, but I’m not talking about adding “tooth” to a polished edge… that is usually a little more strokes.
Stropping a little more after this should get you back to the level you were at.
You’re right, its better not to cause tbis, I’m just suggesting a way to get the edge back after all the work that was done.
I got it. I think we agree actually. I understand that you are offering a repair technique.
My point was that, if this is happening regularly, some close attention should be paid to modifying ones stropping technique.
There is just something that bothers me about spending three to four hours refining an edge to … 0.025 micron levels and then having to go all of the way back to something like the ceramics to make it sharp.
Has anyone tried using the marker with strops? (i.e. to see if your pressure is too hard)
When my strops were new I was afraid of getting marker on them and contamination, etc. Wondering if anyone has tried this?
