I bought my balsa strops with the intention of using the .125 cbn spray on it…. Found out that it doesn’t work very well. After I applied it and tried to use it there was absolutely no metal coming off (ie. A black residue) on the strops. After researching it more, I found that the pores in the balsa strops are semi large and the abrasives will go into them too far and not work properly if you use one that is too fine. I would suggest not going lower than your 3.5 paste on them, but I haven’t actually experimented with this yet.
Can’t hurt to give it a try, but you will see what I mean. At least that’s been my experience. Let us know how it works out!
I don’t think there should be any black streaks or residue by the time you progress to the 0.125 micron CBN, unless you leap there from a much coarser level…
I agree that the pores/grain can be a little big for compounds finer than 1 micron – I prepped my balsa by sanding it up to 3K wet/dry first, and it makes a big difference.
