WEPS Dimensions
Recent Forums Main Forum Getting Started WEPS Dimensions
  • #29338
    developer (ChrisB)
    • Topics: 52
    I am away from home and need to find out the measurements (Height/Width/Depth) of the WEPS with the PP2 upgrade. If anyone can help I would greatly appreciate it. Thanks.
    #29342
    What dimensions do you need, MesaCranker?
    I made some measurements on my PP2 WE.
    • – The vice is about 14 cm high including the low angle adapter.
    • – The LAA itself is about 2.5 cm high
    • – The stock rods are about 23 cm long, when measured up till and including the ball joints
    • – The bar with the angle marks is about 28 cm long
    • – The blue base that holds the vice is about 28 cm long
    • – I don’t know the measurements for the entire bases are, since I made my own base
    #29348
    Pro-Pack II without Granite Base
    11″ (degree bar) x 5-3/4″ (blue base) x 5-5/8″ (height to top of Vise Jaw)
    Weight (without stones) approx 3 lbs
    Pro-Pack II with Granite Base
    12″ x 10″ x 6-3/4″
    Weight (without stones) approx 18 lbs
    Shipping dimensions and weight
    14″x12″x12″
    Weight (with stones) 25 lbs
