The text box for PMs is now bigger, both on the ‘inbox’ layout, and on the notification popup layout. Meaning, if you see a notification and click it, it opens a popup, and we’ve made that text box a bit bigger. If instead, you just navigate to your PMs, you’ll see a larger text box there also. Please let me know if you see any odd behavior, like kicking your cursor back to the previous line, etc. Also, we can make them bigger, if needed. Strategically… If you want the most space to type in, click the notification and then close the popup, then type your reply in the ‘inbox’ instead of the popup.
Thanks for fixing this issue Chris! In the past I have resorted to exchanging emails with other forum members because the PM system has been frustrating to use.
