Stropping pressure
Recent › Forums › Main Forum › Stropping › Stropping pressure
- This topic has 23 replies, 7 voices, and was last updated 02/22/2013 at 5:03 am by
cbwx34.
02/18/2013 at 4:37 pm #9598
The Bluntcut videos are very interesting. I watched all four of them. In the second one he shows how to get an edge with more conventional stropping. That is all good. I now that this works! In the third and forth, he either flails on the knife, or uses lots of pressure ( I have to believe that, if I did what he did…flailing away without looking, the results would not be at all pretty). Apparently it works at some level, at least to cut paper. We know nothing about durability or the ability to perform some of the other sharpness tests.
I’ve applied this strop to many knives at least a month prior to my BF post & videos. Edges are around 90% durable compared to my edge-lead to 0.1um poly diamond stone. And not as clean (burr free) as edge-lead. I can switch back & forth between 2 approach for an edge and still hitting the apex (either manual or EP), so sort of confirm not rounding affect. Also from the paper cutting test, the edge entry cut angle remained low instead elevated even at heavy pressure. Oh well, there is no secret with this strop, so it’s very easy to try to figure out whether it: worked or sort-of or not.
I also think that the eplanation that he give about grit size protecting from rounding the edge sounds plausible, but I can’t say I am buying it with what I know now. Too much time on bench strops that has given me results that simply do not support his ideas.
I really don’t know my conjecture holds water or it’s just a simple grasp a ‘sound good’ reason for why my edges not not look like a bunch of parabolas. I actually have another more far-out explanation but figured that my kevlar vest has poor coverage :dry:
I sure hope people try & tell me why – better than me flailing my arms theory/conjecture.
Then you have people like Cliff Stamp out there that insist that stropping is counterproductive and weakens the edge. He also insists that if you have a genuinely great edge after using stones, nothing you can do with a strop will make it better, only worse.
I am not quite buying that either.
I agreed with you Phil. However there are many variables involve when we are talking about this type of stropping interaction. Hence with a right setup, you can get a perfect-storm to weaken the edge, but the norm for abrasive collides to steel in stropping (pushing away from apex) will has a slight chance of stretching/crack the steel/alloy lattice, which are undetectable or visible, until fracure when in use. In the larger scheme of thing, impact forces from cutting usually many magnitudes greater than a few moleculars weakening. I can see where edge-trail belt sharpening could crack/stretch at grain level, whereby this edge will perform poorly.
In the mean time, I am not sure how what he is doing relates much to the WEPS. At least, nothing I saw is going to make me rethink my techniques using the WEPS. I have never used 8 pounds of force while stropping, and really don’t think I want to start.
IF it works, maybe it can simplify WEPS strop configuration & enhance its effectiveness. Easy route of stropping success for WEPS’s users.
BTW, I use bench strops regularly with from 10 microns down to 0.25 micron abrasives. Nothing I have been able to detect leads me to believe that the edge of the edge is going from 15 to 30 degrees per side after using these strops. I can’t see a burr at 400X, nor can I feel anything that seems like a burr. When I am done, I can definitely push cut phone book paper against the grain and tree top arm hair. I would like to know how he got the measurements to justify his claims.
Take a spyderco vg-10 or zdp-189 blade, strop with CrO 0.5um or 1um diamond at 0.5 lbs pressure. Oh do it for a few minute, I am sure you will get a wire-edge. To guarantee occurence, lower the angle to 20* inclusive. At this angle, I thinkg it’s about 3x more difficult to get a clean edge without burr/wire/rounding.
02/18/2013 at 4:48 pm #9599How did you determine that the diamonds “rounded” the edge.
Fresh sharpened an edge with dmt benchstone all way to 3um, measured angle with caliper. Rubbed on diamond charged strop, measured angle with caliper (iffy read) and use sharpie marker + loupe edge-lead on dmt EE.
What exactly is the white compound that you are using. I have at least three different grades of compound that are all white.
I used/tried
1st – bulk white compound (probably alox) ferrous/stainless-steel rated at 1.2K grit. $5 per lbs.
2nd – Razor Sharp white compound (for slotted paper wheel), as I read – it’s around 15um. $8 per 3oz.I think that hand stropping expressly to remove metal is much different than finish stopping on the WEPS.
Sharp is sharp :cheer:
02/19/2013 at 2:35 am #9600An easy way to test for edge rounding with the Wicked Edge is to use a marker and magnification. Here’s an example: sharpen at a specified degree, then strop. Color in the bevel with a marker. Make a few, very light passes with the stone at the original sharpening angle. Examine under magnification. If there is still marker, only on the edge, then there has been some rounding. Another option is to get some samples made that show the cross section of the bevels i.e. bar stock cut in 1″ or 2″ lengths and then sharpened on the long edge. The cross section cuts would need to be very clean and surface ground very flat in order to observe any rounding.
02/19/2013 at 3:11 am #9603An easy way to test for edge rounding with the Wicked Edge is to use a marker and magnification. Here’s an example: sharpen at a specified degree, then strop. Color in the bevel with a marker. Make a few, very light passes with the stone at the original sharpening angle. Examine under magnification. If there is still marker, only on the edge, then there has been some rounding.
Smart thinking! Not that I’d expect anything else from you of course
, but I’m gonna try this.
02/19/2013 at 7:34 am #9611An easy way to test for edge rounding with the Wicked Edge is to use a marker and magnification. Here’s an example: sharpen at a specified degree, then strop. Color in the bevel with a marker. Make a few, very light passes with the stone at the original sharpening angle. Examine under magnification. If there is still marker, only on the edge, then there has been some rounding.
Or there is a micro bevel.
02/19/2013 at 8:33 am #9612Or there is a micro bevel.
Yes, or that
02/19/2013 at 1:43 pm #9616Fresh sharpened an edge with dmt benchstone all way to 3um, measured angle with caliper. Rubbed on diamond charged strop, measured angle with caliper (iffy read) and use sharpie marker + loupe edge-lead on dmt EE.
First, please do not take this as anything other than a discussion. Sometimes my writing style makes people think I am challenging them. This is not the case, I am truly trying to understand.
How do you measure an angle with calipers. In order to calculate angles for a triangle with any certainty, you really need to know the length of all three sides with precision. I wonder how you do it with your calipers. I would think that you would need to know the thickness of the bevel at a certain point, and be able to accurately measure each side of the bevel precisely from the point where you meaured the thickness. As you mentioned, this is a real iffy thing. I think it is beyond my skills to take such measurements, even with my micrometers, to an accuracy that would get me within tens of degrees, at least, when solving for the angle at the edge. Now some may be able to do this and get sort of “in the ballpark” solutions when the bevel is a couple of millimeters wide. I think it would be almost impossible with rounding that is likely in widths of fractions of a millimeter.
So what am I missing? If there is a technique to do this, it would be valuable for everyone to know it.
One other thing to clarify for us if you will, are these statements about angle changes when you are sharpening by hand… the way you were in (I think) the third video, or are these tests done on the EP.
I have heard it stated that the best hand sharpeners “may” be able to hold +/- 2 to 3 degrees. Though I can get a decent edge on a blade hand sharpening, I am not sure I do that well. I also have a hard time with repeatability between edge leading and edge trailing angles. I have to really concentrate… I could never get even close without looking at the blade….:(
If using the EP, I am sure things are tighter. But I never saw the kind of changes that you talk about when using the EP with HF1 or 525(both white compounds) on leather. Of course I never came close to putting 8 ounces, let alone 8 pounds of pressure on my strops.
I am not saying you are wrong, just trying to figure out why we are seeing such different results. Maybe if I understand your techniques better …
Unfortunately, my idea of sharp, more than likely, does not match yours. In fact I have found very few people that can agree on, or even can agree on accessing, what it sharp. Worse, there are no real standards for sharp, nor edge holding/durability. So when you say that an edge is sharp…will push cut paper that is a very relative metric, as I can sharpen knives with what I see as seriously different levels of sharpness, but they all will push cut paper. When you say an edge is 90% as durable when sharpened on a balanced strop as your other edges. That is meaningless to me because I have no idea how durable your edges sharpened “normally” (edge leading) are.
I do this quite often. I have several knives from Spyderco in both of those steels as well as M390 and a few other 62+ Rc blades. I strop them in between sharpenings on the WEPS for maintenance, as I do most of my knives. I have not yet detected a wire edge. I would see it if it was significant at 100X. I would sure know quickly if my edge went away after cutting the first piece of rope, cardboard, or tie wrap. This simply does not happen!
So, again, no right or wrong here, I just don’t get it. Help me out.
Hey guys, I know that I have read that several of you use strops for maintenance. What kind of results are you getting?
One last question., Where does one find a 0.1 micron poly diamond stone? I would love to get my hands on one of those! 0.49 is the grit advertised for the Shapton 30K, and that one is finer than frog hair….
02/19/2013 at 3:43 pm #9621How do you measure an angle with calipers. …
So what am I missing? If there is a technique to do this, it would be valuable for everyone to know it.first, with heavy pressure and if rounding occurred, it either dull and or entry angle into cutting paper will be more obtuse.
Draw 3 lines using marker from spine to apex, with 5mm gap between line. triangle1: dialed caliper to 0.25, insert into blade next to line 1, slice across line to mark the triangle base, aid with loupe measure the triangle side. Repeat for other 2 lines, with 0.5mm and 1mm respectively. Stropped and measure to check angles before vs after.
I also stropped using EP then checked using marker.
Once the angle maxed-out on the + a few degrees. That is the baseline angle. Since strokes at lower angle most likely won’t hit the apex anyway.
My main goal for those videos was to make stropping simple, anyone can do it. Simple baseline is to make it sharps and not going dull when repeat & heavy pressure.
Percentage is subjective to how I tiered sharpness level. Tests & cutting styles are subjective also. 90% sharpness is threshold the edge cut or rip slice newsprint at 45* angle.
I do expect that you don’t have any problem, since you use techniques that known to worked for you. Whereas 99.999% people in the world do not. In order for you to experience difficulty/challenge, that why I suggested go 20* inclusive or lower angle. When I pushed my Spyderco Stretch zdp-189 to 14* inclusive, its wire-edge is hell-ish to clean.
I posted how-to-make this stone on BF before. Basically heavy stock photo-paper, wet-it & wait, spread 0.1 polydiamond suspension/paste on it, heavy-pressure-roll-over using steel/ceramic rod to embed the diamond, wait 24hrs. Voi’la a stone which support edge-lead stroke (with care of course). You certainly can strop with this stone. Cost per 3×8 paper stone is around 10-20 cents, depend on diamond density. Oh, I did stropped on plain heavy-photo-stock-paper for 5 minutes, the coated white clay was too soft to abrade steel.
edit: here is the video where I used these paper diamond stones
02/22/2013 at 5:03 am #9654Wow… a lot going on in this thread!
I focused a bit on the point of whether or not a burr can be formed by stropping. While I’m sure it can… and I think I remember this being talked about more when sharpening razors for shaving… for the most part on knives, I think leather does a better job of cleaning up an edge vs. forming a burr.
I noted two of the steels mentioned, VG-10 and ZDP-189 can be difficult to debur in the first place. They can also fool you into thinking the burr is gone, until you use it. My own experience… I’ve had knives that I’ve sharpened… thought were burr free, stropped on leather, then used only to find a burr. I think it was there all along, I just didn’t detect it. My belief is supported by repeating the same without stropping, and again detecting a burr in use. Whether or not this is the case in Bluntcut’s example is hard to tell… but in the end, what works for you is probably right.
A couple of older threads are worth reviewing…
Stock stone/strop progression. Razoredgeknives does a good job in the first post in indexing some of the photos showing edges at various levels.
A theory of how the WE pastes work.. Another thread with a lot of discussion and pics.
There’s some other threads in the Stropping section worth looking thru for additional info. (If you find something good, link it here.)
As mentioned, a lot of knife users maintain their knives with a strop. Over time, a touchup is needed with a stone or other abrasive, but I’m not sure that’s a matter of the strop “degrading” the edge, as it is the strop not being able to “keep up” with the normal wear and use? Especially if you use a finer abrasive.
You both have given me lots to think about!
