Hey Brian,
Allgonquin hit part of the equation… The level of finish plays a part. Also if you’re using leather to strop, you might take note of Clay’s recent photos on how it can round the edge,,,and avoid this by stropping at a lower angle.
The edge feeling sharper in one direction over the other is determined by the direction of the striations left on the bevel by the stones. If you sharpen in the “standard” direction, from heel to tip edge trailing, you’ll leave “teeth” pointing toward the tip, which will catch and start to cut as you move the material from tip to heel. I sharpen this way cause it’s faster, but when I get to the finer grits, I reverse direction. You can also try a more straight up and down stroke, and work up and down the blade in sections. You can vary it depending on how you plan on using the knife.
Hope this helps!
