Oil on stock diamond stones… your thoughts?
Recent Forums Main Forum Sharpener and Accessory Maintenance Oil on stock diamond stones… your thoughts?
Viewing 14 posts - 1 through 14 (of 14 total)
  • #3613
    so I just noticed that a few sets of my stock diamond stones (400/600, 800/1000) had rust spots on them! didn’t think I put them away wet since I always lay them out on a towel to air dry. anyway, i was just wondering what you guys think about putting a very little amount of oil on each stone and rubbing it in? I’m not talking about an abundance of oil like on normal stones… just enough to keep it from rusting. and just to let you know, I already did this to the listed stones (with weapon shield clp oil) … they look fine but ill try to report back. I. normally just jump right into stuff and it costs me later but oh well lol.
    #3614
    BassLake Dan
    • Topics: 11
    so I just noticed … .rust spots …didn’t .. put them away wet .. oil.. just enough to keep it from rusting. .
    Oh boy, nothing better than a little chemistry! here we go: rust is iron Oxide, the result of a reduction reaction which involves oxygen. So you have two choice here to prevent that reaction. first (and the best) is to take away the source of the oxygen which may sneak up around you without you realizing it. Look to eliminate powerful oxidizers that may be around your storage or work environment. Things that contain or outgas chlorine are always suspect, common household cleaning agents are always suspect here. Common garden fertilizers contain nitrates, do you sharpen or store the plates in an out building or near a storage shed that contains such items i.e. ammonium or potassium nitrates? Also look for any compounds that contain perchlorates, sometimes used in fabric color fast bleach formulas like Oxy-Clean. Water can release oxygen thru hydrolysis but if you dry the plates this is unlikely to be the cause. Do store the plates in a room with less than 40% RH humidity, anything over that is suspect.
    After you track down any sources of oxygen or chemicals that are either powerful or mild oxidizers in your work or storage area then: Your second best approach is to use oxygen barrier coatings. The oil you mention is this type of strategy, but there is better chemistry available to you. VCI or Vapor corrosion inhibitors are an inexpensive way to win the battle. There is a whole slew of products in this arena. Just google for VCI paper and you will get many vendors. Here is a link to try
    #3615
    So what is the iron in here? Is it from the knives you sharpened? That shouldn’t be too bad. Is there any other source of iron in the stones?
    Thanks for the link to the VCI paper. Interesting stuff. I’d never heard of it.
    #3616
    Steven Pinson
    I would just clean them with a little 91% ISO Alcohol and throw them in a box with a desiccant pack.
    #3623
    those are all good points… but i am storing them where i always have… but now all of a sudden they have some rust spots on them. i am wondering if i put them away damp… thanks for the VCI paper link Dan. I know I could get some silica gel packets and throw them in there… but that would be a pain. I will see how this drop of oil works out I guess… since I have it on hand already! hehe just checked them today… they look good. i just wonder if the oil will have any long term effect if i am cleaning them with hot water and soap each time before the drop of oil.
    dan, what do you do w/ the VCI paper… just wrap your stones in them for a time or two for the molecular change to adhere to the surface of the metal?
    #3624
    BassLake Dan
    • Topics: 11
    So what is the iron in here? …
    yes the steel is from the debris of sharpening but also,the base material of the diamond plates is steel, all of which is an alloy of iron 😉 .
    #3625
    BassLake Dan
    • Topics: 11
    you can certainly do that,.. or I think many vendors sell the VCI in a spray that you can apply directly. That might work better for you in this application. It is all cheap enough stuff to give various approaches a try.
    #3626
    BassLake Dan
    • Topics: 11
    But, anyway, not trying to out chemistry you here 😉 , but the problem with that is that water is 100% soluble in alcohols (well except polyvinylalcohol anyhow..) It is also hydroscopic as hell so it just sucks water out of the air. That is why the bottle you have of the ISO you mention is labeled as 91%. It is 91% alcohol and 8% water. The alcohol has a very high vapor pressure but the water does not, so after a short time guess what? The Alcohol is long gone but the water remains. You only get 100% under lab conditions, and then only for a short time..
    Anyway the VCI is going to a be a great fix for the issue especially if the storage periods are long and unsupervised. Say for instance, you pack away you WEP kit for a while, take a vacation, Winter over in Mexico, like it so much you hang out for a month or two longer than you planned. During that time your kit is sitting in you garage workroom where the RH is 100% during the season.. The VCI prevents the nasty that might be, otherwise, waiting for you upon your return !
    #3628
    yes the steel is from the debris of sharpening but also,the base material of the diamond plates is steel, all of which is an alloy of iron 😉 .[/quote]
    Have you got any idea what the base of the diamond plates is made of? I usually use a liberal amount of water to clean them, but that might not be the best idea…
    And regarding the iron from te sharpening debris, wouldn’t it be better to let it rust away? The debris just fills the space between the diamonds, which makes the plates less effective, I’d guess.
    #3637
    Ralph Honeycutt
    What do you think about using a product such as Balistol which emulsifies with water and has multiple sportsman applications? I have not yet tried it. I was looking for a chemistry lesson on this before I try it. I use it on firearms as a solvent/lubricant. The Ballistol odor may result in the user being exiled from the house to the garage as it smells like dirty socks.
    Ralph
    #3639
    The base material nickel plated steel. I also use water to wash the stones and haven’t had any issues w/ rust but I live in a VERY dry place. With all the pushing and shoving of the diamonds into the base plate, it wouldn’t be surprising to have the diamonds puncture through the plating. I imagine that moisture can get into any imperfection in the nickel plating and rust the steel underneath.
    #3643
    BassLake Dan
    • Topics: 11
    … wouldn’t it be better to let it rust away? The debris just fills the space between the diamonds, which makes the plates less effective, I’d guess.
    You might be on to something there, that is an unconventional but very interesting idea. I once made a post in another topic thread about the possibility of cleaning ceramic stones with acids, which is the same methodology, whereby you use reduction chemistry to your favor ( eat the ‘bad stuff’ and leave the good :sick: ) . Such an approach is safe with ceramics but there is danger here with the steel base.
    #3649
    Yes, that inspired me 😉 . Soon after your post I ordered some oxalic acid (apparently also the/an active ingredient in Bartender’s cleaning stuff), which came in the form of crystals that should be dissolved in water. It did… nothing. Then I did a PH test on various solutions and the stuff had a PH of… 7! So apparently not (oxalic) acidic. Then I got into an argument with the supplier of the stuff and after having been called names (my first experience in this with a webshop 😆 ) I managed to get my money back.
    That was my attempt to obtain an acid for cleaning ceramics. Any ideas for other places where I might be able to obtain an acid that may helps in cleaning ceramics? Where I live this is quite restricted and I had no luck at drug stores or pharmacists.
    #3658
    BassLake Dan
    • Topics: 11
    humm.. I thought several suggestions was made in the thread at :Link here::
    since it is late here tonight and I am lazy anyway.. I will just requote from there, with the additional information that I did try using distilled white vinegar in a crock pot and it took almost 36hrs (!) to clean a dirty Spyderco Ultrafine.. so battery acid would be a bettery way to go, BUT be very careful, it is very poisionous and the fumes can be explosive and hazardous. That was the reason that I never responded further to the thread nor did I add any details. Chemistry is not for everyone 😉 Here is some from the original thread if you missed it..
    “So acids are the ticket really for ceramics. Around the house you can find a ready source of H2SO4 in any lead acid flooded battery. Consult your local auto repair shop for a sample. Samples of other, much milder acids, like Oxalic Acid can usually be found in the formulations for espresso coffee machine cleaners. Sources of other mild household available acids would be distilled vinegar which is a source of Acetic Acid. It might be interesting to try an experiment with my dirty ceramics featured in the previous post. I will soak them overnight in a hot crock-pot slow cooker filled with some distilled vinegar. These reactions are accelerated by heat, so therefore the hot crock would be a good idea with the mild vinegar: (caution: never heat H2SO4 and attempt any of these experiments, results can be violent and dangerous!) “
