New Longer Arms for Pro PackII & Low Angle Adapter
Recent Forums Main Forum Suggestion Box New Longer Arms for Pro PackII & Low Angle Adapter
Viewing 14 posts - 1 through 14 (of 14 total)
  • #14541
    Bill
    I just received my Pro-Pack II Upgrade Kit & Wicked Edge Low Angle Adapter. Now I would like to obtain/build longer arms.
    Does anyone know what material & diameter is used for the Pro Pack II arms? As suggested in other posts, I think 4 inch longer arms would be about right.
    I found a post by PhilipPasteur giving the following info on new arms:
    http://www.mcmaster.com/#catalog/119/3699/=n1ngy9
    Is what I boutght for the rods…
    Stainless Steel (Type 416) Precision Ground, 1/4″ Diameter.
    Also, what adhesive tape is used to attach new stones to the plastic paddles/handles.
    Thanks for the info.
    BB
    #14550
    Fred Hermann
    • Topics: 30
    I am not positive, but I think you have the right rods.
    Personally, I want some that are about 2 feet each so I can do swords. Might be a PITA to use, but its the easy option to try. I wish I could thread them myself, but that’s yet another tool I need to buy if I go this route.
    As to tape, there was discussion on stones falling off and the tape a while back, I think in this forum folder. I have to hit work, but if you don’t find anything, I’ll try digging too.
    I do know there has been ongoing research on tape, and Clay has tried many types looking for the right tape for the right stone.
    #14553
    It’s a 3M tape. If you phone Wicked Edge and ask them nicely, they can probably provide you with some.
    #14601
    Bill
    Thank Fred and Mark.
    I have ordered some steel rods,some heavy duty joint ends, and a bag of replacement screws for the jaw vice from McMaster Carr.
    I found this very interesting video on the 3m tape.
    I ordered some of the tape from ebay. I will let everyone know how it ends up.
    I will have plenty of the vice screws left over. Let me know if anybody would like a couple of them (just pay postage)
    Bill
    #14605
    Fred Hermann
    • Topics: 30
    Great video and PM sent.
    #14610
    Just curious….what vice screws (size) did you order?
    I saw that same video on TV the other day… looks like good tape! Keep us posted.
    #14611
    We use 3M 4932 VHB tape for mounting diamond plates to the handles and it’s pretty bombproof, so if you’re mounting aluminum or steel backed stones, that tape is awesome. We’ve been struggling to find the right adhesive for mounting the ceramics. We’ve tried a few that our local distributor recommended but they haven’t worked as well as needed. The ceramics are hydrophilic, meaning they love water and absorb it. Once the stones absorb enough water, it interrupts the bond between the tape and the stone. We had the 3M guys out last week and went through all our products and applications. They’ve got some new tapes and an adhesive promoter that they’re sending out to us to try. The adhesive promoter seals the surface of the stone, giving the tape a surface to which it can establish a super strong bond. I’ll report back once we’ve tested the new products.
    #14612
    R. Jeffrey Coates
    • Topics: 9
    :woohoo: The 3M video about the tape was AMAZING.
    #14613
    R. Jeffrey Coates
    • Topics: 9
    I’m not an engineer but it would seem that to prevent the water from migrating through the stone you would need to seal all sides, even the side being used to sharpen. Two initial questions:
    1. would the sealant change the property of the stone
    2. if not #1 above, would it stand up to the abrading with the stone?
    I used to use an old epoxy that would fit almost everything: MARINE TEX. It would cure under water, hot or cold. oil proof too. I have seen it used to “glue’ a cracked engine block together – through oil residue. then sanded and drilled and tapped. It’s good stuff.
    If you are old like me you might remember seeing the shelf demo in your old hardware store . A soda bottle glued to wood, a golf ball glued to the top of the bottle and a hinge glued to the bottle.
    I bet a little bit of that would hold the stones to the paddles.
    #14620
    Bill
    Thank you for all the comments. Curtis – I ordered the 3/4″ vise screws. I have found you can always make them shorter with a mill file.
    I will take pictures of my new setup latter this week.
    Bill
    #14622
    Leo Barr
    • Topics: 26
    I am awaiting my WE but I currently have an EP and it was recommended that I use 3m spray glue to mount the stones to an aluminium plate I bought something similar in Spain but I found shaking the can for 2 minutes at a time and then clearing the nozzle tedious so I use normal contact adhesive it works well and when the stones are shot I pop them in to a saucepan & simmer them for a minute or so then I can lift the spent stones off clean the plate ( I use an aluminium wire dish cleaner to clear the glue off the plate )then mount a new stone.
    If you use epoxy two pack glue yes it sticks well but you can never remove it .
    Contact adhesive is good and very inexpensive .
    #14631
    I actually wonder about what Leo said also…. I’ve used 3M77 spray on EP stones and have left them soaking for weeks in water without issue. Is there a difference between those stones and ceramics?
    #14632
    The adhesion promoter creates an impermeable layer on the underside of the stone, so the water can soak through the stone until it hits that layer, and then it stops. The tape bonds to the impermeable layer and works as well as if were bonded to our metal or glass plates. At least this is what the 3M people are telling us. We’ll do a lot of testing once the samples come in.
    #14637
    DARRELL ALLEN
    • Topics: 15
    So far Clay, my super fine ceramics that came off the platens a while back, and that I told you I used a thin coat of medium CA glue to re-adhere them, has held up just fine…….no more issues. 🙂
