Mod to sharpen a Spyderco knife
Recent Forums Main Forum Knife Specific Discussion Spyderco Mod to sharpen a Spyderco knife
  • #24668
    Spyderco knives are a challenge to sharpen because of their ricasso next to the choil. (Well, a ricasso is unsharpened by definition, but I like to sharpen the entire edge.)
    Some people mod their stones, sanding off the plastic ridges, in order to be able to sharpen this ricasso.
    I prefer to mod the knife. This is my new Paramilitary 2.
    #24676
    Alan
    • Topics: 16
    Mark you did that just perfect. If I didn’t have a Spyderco PM2 myself, I’d have a hard time seeing what you did. You use a dremel? Anyway, nice work!
    Alan
    Alan
    #24697
    CliffCurry
    • Topics: 42
    Having just redone my para II and running into that same spot, Id be interested how you did that as well. Looks great!
    #24698
    Daniel maloon
    • Topics: 10
    I agree with Mark. I explain to customers what needs to be done and why. It’s up to them. I hand file blades with a diamond file. I’ve seen enough damaged blades from dremel lol. You other guys know what I’m talking about
    #24734
    Steven N. Bolin
    • Topics: 47
    I’m so quick to reach to reach for my Dremel, especially with the Flex Shaft which doesn’t give you the level if control you hope for… At such high RPMs, and a very short amount of abrasive contact with whatever material, it’s destined to jump on you out of nowhere!… I think it’s because being able to properly use a file takes years to master.
    #24741
    Thanks guys! I did it with a Dremel using a small round diamond grinder. I have a battery-powered Dremel that can rotate really slow.
    I intended to also use a small rod with fine sand paper or use a fine file, but that wasn’t even necessary.
    #24745
    Steve
    • Topics: 21
    Nice mod there mate 😉
