Maintaining Waterstones for use on the Wicked Edge
Recent › Forums › Main Forum › Sharpener and Accessory Maintenance › Maintaining Waterstones for use on the Wicked Edge
- This topic has 40 replies, 10 voices, and was last updated 09/03/2012 at 11:43 pm by
Ken Buzbee.
04/05/2012 at 4:10 pm #2531
Well this may be a boring topic at first glance, but I assure you that for any serious sharpener it is one of the more valuable things to grasp thoroughly.
Diamond plates wear out. There’s no getting around this. You can slow it down using plates wet to keep from abrading the substrate that holds the diamonds in place, but eventually they wear out. Sandpapers of all types wear out too. But they maintain their shape during this period. In part this is because they present essentially a single layer of abrasive and once it is gone, that’s it. Diamond plates do wear VERY slowly, so it is certainly not a cause for panic or a reason not to use them. There are diamond ‘stones’ that have diamonds going through a depth of material but they aren’t used by sharpeners for reasons beyond this topic.
Then there are sharpening stones. Some, like Arkansas stones wear slowly – but cut slowly too and are available over a relatively narrow range of grits, going as fine as the translucent stones with the surgical blacks next in fineness and other coarser ones available. They can be used with water (my preference), oil or plain. They are useful in some instances but primarily on knives of lower abrasion resistance – European kitchen knives, soft Buck knives, etc. There are also India stones etc but let’s go on.
Next are both synthetic and natural Japanese waterstones a personal favorite of mine. These are available in a very wide range of grits from ~ 24 grit to 30,000 grit. Instead of a single layer of abrasive the whole thing has abrasive content so there is MUCH more abrasive present. Natural stones span an even wider range of grit sizes although not a lot more, primarily at the high end.
They do wear at various rates. In general softer stones and coarser grits wear fastest but this isn’t a direct relationship. Thus several different waterstones, all 1000 grit will have different wear rates, different hardnesses, abrasive density, binding structures and so on. As you use these stones, you will find personal preferences for how you like them to wear and find that you will actually PREFER a faster wearing stone for some applications.
So stones wear. This is a fact of life that any even moderately serious sharpener must understand and work with.
Stones wear unevenly. Why? Because sharpeners (I include honers in this term) sharpen unevenly. For freehand sharpeners, this wear pattern is almost like a signature. For WE users, this is a property of the way the stone is used. For instance, the two far ends of the stone wear less because we don’t run the edges to the very ends of the stone – nor should we as this risks damaging the edge we are working on. We don’t press evenly throughout the length of the strokes of the paddles. You might press harder on the left stone than the right or need to correct a bevel by grinding more on one side or the other or by twisting the stone, causing more wear on the right or left side of the stone. And on and on. I could spend a day with examples here.
So eventually we get our stones out of being ‘square’. Typically they ‘dish’ or are thinner in the center and thinner to either side of center. In the extreme they start looking like a saddle. Similarly diamond plates will wear unevenly but just become less effective and aggressive rather than dish.
What to do? This is a key concept:
You MUST be able to keep the surfaces of a stone FLAT. This is as much a part of sharpening as anything else and a key to success. You will at times also need to readjust the stone to make the flat surface parallel to the back of the stone or plate. This is less critical, but still important.
Now before we delve into this topic, I need to address another very important topic of particular relevance to the Wicked Edge and other devices like the EdgePro – stone thickness. This is NOT a limitation of the Wicked Edge but rather a much more universal issue for ALL users of stones.
SO let’s jump ahead and say that you are now a master flattener and truer of stones and that you now have in your possession a set of stones of IDENTICAL thickness – perfectly flat and true.
So you start out on a knife needing some serious work with a ‘butter knife’ dull edge and chips – the type your neighbor sends you
You start removing chips with a coarse stone and progress up once the knife is repaired up through a series of grits to say a 5000 grit edge. Or maybe you have a better knife and go all the way to 30000 grit.
Now lets say you do this to 10 knives. By now your stones have dished – not terribly but less than perfect (I promise to return to this more later).
You need to flatten the stones. Yes, you do. So you flatten and true them. Now you measure the stone thicknesses. Do you think that all these perfectly flat and square stones are the same thickness?
They will NOT be. WHY? Because they wear at different rates. This is a fact of life. In general, your finer – and most expensive – stones wear slowest. Thank God! You will completely wear out your coarser stones long before your fine ones. So stones like a 30k Shapton will probably never get replaced from being worn out – and not used on ‘lesser knives’ or knives not requiring that level of finish. But especially if you do a lot of sharpening you will wear out your coarser grits first.
The solution to this is NOT, absolutely NOT, to grind down your 30k stone to the thickness of your coarsest stone. Your solution is to adjust for the difference. How? Use an angle cube to be precise. Got a softer knife and need less precision (but still FAR more than freehand sharpeners can produce)? Use a Sharpie permanent marker on the edge and using a light sweep of your next finest grit make a small lateral sweep over a small part of the edge and see where you are at. With a little practice you should get to within a few tenths of a degree in just a few swipes using the continuously variable adjustments – not the premarked notches. If you are off a couple tenths this next grit will fully compensate and give you a clean single bevel angle with just a few more strokes. Not perfect, but if you want perfect – measure.
The old adage ‘measure twice, cut once’ applies here very strongly. Perfection takes more time. With a device like the Wicked Edge, you approach perfection far more closely than freehand and you see things less than perfect more easily. Slop unnoticed by a freehand sharpener becomes obvious, much like seeing one item moved on a clean desk versus one item misplaced on a desk piled high with everything that hasn’t been taken care of.
I’m going to stop here for now and continue this topic in subsequent posts on this thread for emphasis of this one point of stone maintenance – dealing with the variations in stone thickness as a stone is used when comparing coarse stone wear rates to finer stones.
Ken04/05/2012 at 5:07 pm #2533That is REALLY informative, Ken. Please do continue! I am very interested in the best way of flattening waterstones. I hear many different opinions: two stones of the same grit size against each other, use of diamond stones, special lapping plates…
04/06/2012 at 12:21 am #2537“Now lets say you do this to 10 knives. By now your stones have dished – not terribly but less than perfect (I promise to return to this more later).”
OK, I did promise. I’ll explore several methods of stone flattening here and later talk about leveling your stones. I’ll present this showing my biases and please take them as that. There’s more than one way to accomplish things. I’ll probably talk about texturizing stone surfaces later on too, a related topic, which then extends into slurry formation techniques and so on …
Ever wonder why the pyramids had stones that fit so well together? Or the Mayans or other cultures? I see some ‘experts’ marvel at this ancient precision. But yet the answer is so simple – knowledge more in the hands of craftsman than academicians. If you rub two stones together they wear the high spots off and eventually they fit closer and closer together. Indeed when using water especially they can stick SO close together that they actually DO stick together. This is termed STICTION. Stiction can be your friend OR your enemy. Now for our ancient bricklayers, even with HUGH bricks, this is good enough. For some sharpeners this too is good enough. But is it really? Well, pardoning the risque analogy, but think of two lovers and not necessarily two thin ones (sorry). Their bodies melded together as one. The bulges of one are met by the depressions of the other into a close union. But are either of them flat? Not necessarily. Or more bluntly, NO. So it is with rubbing two stones together. It is an improvement but not true flatness. For greater flatness, you use three stones, rubbing them in pairs = A+B, B+C A+C averaging out the three surfaces to a pretty precise flat surface. This is how ancient Japanese leveled their stones – and at times some still do. Ideally you would want three identical stones, but often use a coarser stone for leveling. There can be issues of grit contamination here, but that’s another topic. And these days the luxury of having three, let alone one expensive natural stone is not often practical. For a coarse natural stone to use for flattening, stones like an Ohmura or Hirashima are sometimes used, as the Ohmura can take sustained submersion.
We also have modern ‘flattening stones’ These are typically coarser stones of varying grit from as coarse as 24 grit to 120 and even 220 grit. Norton, Naniwa and more recently Nubatama have stones of appropriate coarseness that maintain their shape relatively well. They work well but eventually require flattening themselves. And here we are back to the above three stone technique. Personally I find these stones not too useful for Shaptons, because they just aren’t effective for abrading the surface of these abrasion resistant stones. But for softer badly dished stones this is an alternative.
In some instances, you can sprinkle Silicon Carbide on the surfaces of these stones to make them cut better – available in various coarse grits. You can even use Silicon Carbide on a soft metal flat surface or platen’. You can also use glass as the flat surface. I personally find this technique messy but it can be useful for coarser stones.
Some use a sidewalk for badly dished stones, plus water or not. Personally I HATE this technique because of MASSIVE contamination issues and would never recommend it. Might just be that the sidewalks I’ve used might not be good sidewalks or that people don’t care for masses of colored mud laying around – especially neighbors. Avoid this.
So we get to what I prefer for flattening stones – diamond plates. They ARE flat. How flat? This varies. Good high quality plates – Atoma and DMT are VERY flat in the range of within 0.001 inches over the surface of the plate. IMO this is more than adequate for the most discerning of tastes. You can get even flatter with the Shapton Diamond lapping plates, but I feel this is excessive. Tom might disagree
Diamond lapping plates are available in various grits. I use plates as coarse as 60 grit but typically for Atoma plates you have 140, 400, 600 and 1200 grits. For DMT (and I prefer the diasharp series) grits are 120 (XXC) 220 (XC) 320(C) and fine and extra fine (1200) and XXF(8k) You also have diamond films as an option here from as coarse as 165 microns and 125 microns up to finer and finer grits that you can use for texturizing (another topic). While the DMT plates work quite nicely and are a continuous surface of diamonds in a nickel matrix, they do develop a great deal of stiction and the more expensive Atomas offer better performance. I’ve used DMT’s for years and they are an excellent product but for stone flattening the Atomas are superb. I have not used the Wicked edge diamond plates for stone flattening yet, but because of size, they might be an alternative but something a bit larger might be better for stone flattening duty. I’d be interested to here other’s experiences here.
So you have your diamond surface. What grit is ideal? Well coarser grits leave a rougher surface texture and get the work done quicker. But they leave deeper scratches and wear the stone faster sometimes unnecessarily so. So, for a badly dished stone, use a very coarse plate (eg, 140 Atoma). For coarser stones – also a coarse plate. A finer plate on a coarse stone wears the diamond plate faster. And a very coarse plate leaves a more aggressive coarse stone surface, which is desirable. For finer stones – 1k and above, I use a 400 Atoma, since this leaves a smoother surface or a DMT coarse, however the DMT coarse has very strong Stiction issues so you need to move fast and use lots of water. This also produces a minimum of wasted stone to create flatness.
Now flattening is something to be done OFTEN. How often? Depends on usage. But even done quite often your finer stones will last for years of use. It is better to flatten as a minor touchup often than to flatten a badly dished stone. This is analogous to keeping a knife sharp with little work or waiting until it gets very dull and doing a lot of work. It is counterintuitive, but you waste LESS stone flattening than working on a dished stone. AND you get far better results and waste less metal on your knives with a flat stone. I should probably expand on this point if someone asks.
It is a matter of technique to minimize stone wear by trying to use a stone evenly concentrating on the high spots when you can. This is an issue of technique that can be discussed later.
Next, having discussed flattening equipment, we will discuss flattening technique. Please ask questions as I write these mini lessons so that I get some feedback if this is addressing issues of interest or is/isn’t hitting the mark or if I’ve explained something poorly.
Ken04/06/2012 at 1:40 am #2539Great post Ken, thank you! I’m moving it to a new category call Maintenance and making it a sticky.
04/07/2012 at 2:58 am #2560Thank you Clay for putting this topic as a sticky!
Ken04/07/2012 at 4:25 am #2565Great post Ken, thank you! I’m moving it to a new category call Maintenance and making it a sticky.
At the risk of getting yelled at for cross=posting I am hereby going to be so bold as to copy one of Kens Excellent posts to this thread/. Some of Ken pearls of wisdom are so well stated that I would hope we can get an entire thread of them in one sticky place so that I, and perhaps others, can refer back to them from time to time. So here is one that I have read and re-read several times. It is just right on target!
Quote from Ken “… I thought I knew what sharp was, but I have proven myself wrong so many times that now I just look forward to reaching the next level.”…
This is a difficult topic as no one has found a definition of sharpness that covers all cases and that satisfies all their needs for evaluation. In short, it is a tower of Babel.
Take the CATRA testing. It is essentially evaluating push cutting performance under strict guidelines. It is setup to detect the instant that a cut starts. Essentially a burst injury type of separation. It tells you very little of slice cutting performance. It also tells you little of how a blade’s overall geometry contributes or inhibits the ability of a knife to pass through an object or objects of different density. So, for instance, if you cut a cucumber slowly it may not cleanly separate, but with a bit more speed the inertia will ‘follow through’ and you get better separation. This is different than a straight push cut vs a slight slicing motion when contacting the board. People have used string extended over a platform on a scale, and taring the platform’s weight measured the point where the string is cut. This is fraught with string consistency issues, string tension issues, matching the string performance to the force range of the cut and variance along the edge, etc.
In a practical but imperfect sense, I use the ability of a knife to slice or push cut through copy paper as one index. For push cuts it is a direct downward motion perpendicular and from a point of touching the paper. I measure how far out from a pinch grip it will do this, eg push cutting 2 inches from a pinch grip. There are ways to cheat on this and edge thickness and angles change the values for equally sharpened edges. Ultimately the ideal test of sharpness is done by using the knife for it’s intended task.
Not all knives are sharpened the same along their whole length, so ultimately you have to sample along the whole length. So for instance, a deba might have a less acute angle at it’s heel than it’s tip because the heel is used for chopping off fish heads and the tip and midsection for filleting the fish so the angle is varied along it’s length in a continuously variable fashion. This CAN be done with a WE.
Sharpness is not the only goal involved in sharpening a knife. You trade for longevity of the edge, the task it will be used for and so forth. In some instances aesthetic considerations may even exceed sharpness requirements. This is a topic in itself, which can take into account both personal and cultural aesthetics. In some instances like shaving, comfort may be of equal importance to sharpness.
This doesn’t even begin a discussion of defining sharpness.
Ken04/07/2012 at 8:24 am #2566This is a fascinating read, Ken! Really “everything you ever wanted to know about stones, but were afraid to ask”. And more. If you’re ever going to write a monograph, I’ll be one of the first to read it.
A quick question: what is the difference between a diamond stone and a diamond lapping plate? Two different names for the same thing, or two different things? And my local dealer sells a Naniwa Nagura stone. It this an example of what you call a modern flattening stone?
04/08/2012 at 5:25 pm #2579Dan and Mark, thank you for the kind words. Much appreciated.
So a diamond plate has a layer of diamonds typically embedded and partially exposed in a metal bond matrix, typically nickel, whereas a diamond ‘stone’ has diamonds dispersed inside the (typically harder) matrix to various depths or the entire ‘stone’. You also can have resin bonds and hybrid bonds, but this goes off topic. These ‘stones’ are typically used in industrial processes and really not suited for hand sharpening operations. These are used for tasks like polishing the insides of engine cylinders and hydraulic pressure lines are used to exert pressures well beyond hand sharpening pressures. Typically if used for hand sharpening they will glaze over because the surface won’t refresh adequately. These are also dimensionally precise ‘stones’ and not using as fine grits as we sometimes use for knife edge production. They are also rather expensive with stones barely the size of WE blanks costing hundreds of dollars.
Naguras is a large topic worth a separate discussion or several. The stones that accompany the Naniwa Chocera stones are often mistakenly referred to as nagura stones. They are not. They are simply waterstones. In this case 600 grit waterstones not too dissimilar in composition to say an 800 grit
King brand stone.. They should be referred to as cleaning stones, used to clean off metal swarf that gets caught in stones, typically from running a stone too dry. They are too small to flatten a stone adequately and can be used as a small 600 grit stone and certainly not as a true nagura stone. I rarely use these if at all. True nagura stones are a completely different topic. If a stone gets too much embedded metal swarf in it simply lapping it with a diamond plate both removes this embedded metal swarf at the same time it flattens the surface.On to stone flattening technique in the next post. Hope this answers your question adequately.
KenThis is a fascinating read, Ken! Really “everything you ever wanted to know about stones, but were afraid to ask”. And more. If you’re ever going to write a monograph, I’ll be one of the first to read it.
04/08/2012 at 10:36 pm #2582Excellent stuff, Ken! B)
Keep it coming!
04/15/2012 at 5:27 am #2770Thanks again, Ken. I think I understand your explanation of the difference between stones and plates. The only thing I don’t understand is that these stones are so expensive. The Wicked Edge diamond stones cost $65 for two paddles. That is not exactly cheap, but also not hundreds of dollars per stone. Or are the WE diamond stones technically diamond plates?
And to make a shortcut: is a course or medium WE diamond stone suitable for flattening a fine WE Chosera stone?
04/15/2012 at 1:03 pm #2774Thanks again, Ken. I think I understand your explanation of the difference between stones and plates. The only thing I don’t understand is that these stones are so expensive. The Wicked Edge diamond stones cost $65 for two paddles. That is not exactly cheap, but also not hundreds of dollars per stone. Or are the WE diamond stones technically diamond plates?
I probably shouldn’t go too deeply here as it will only get confusing and off topic. When I reference ‘stones’ vs plates, I’m referring to the WE diamonds as plates – Just like DMT or Atomas or films are plates. They have a layer of diamonds on their surface. When I mention ‘stones’, that is really a misnomer for a chunk of material that has diamonds going down into the matrix not just on the surface. Typically this is a metal matrix, not a stone matrix. In all likelihood you will never see one outside of an industrial environment. They are quite expensive because they have a LOT more diamond in it and (having tested one) are largely unsuitable for hand sharpening.
I would think the WE plates ARE suitable for stone flattening, but would suggest using water for this task and being careful to cover the whole stone. More about this later …
Ken04/15/2012 at 3:00 pm #2775So we have discussed the various types of equipment available for stone flattening up to this point. Overwhelmingly, I prefer to use diamond lapping plates for this task and will focus on this for the remainder of this discussion and let the reader extrapolate from that how to use other surfaces for flattening.
The purpose of flattening is straightforward – to produce a flat surface. This is different than producing a surface that is parallel to the back of the stone to form a perfect rectangular cuboid, but this will be covered in more detail in a post to follow.
So why do we want flatness? Well this is actually an interesting question.
I believe the answer to this is that we want a very close and uniform contact between the stone and the knife edge. Why? To give a uniform result. We don’t want to just be hitting high spots but rather we want to generate a uniform surface so that as we proceed from one stone to the next we are hitting the same surface evenly. And also producing a uniform surface on the edge as well (either flat or convex but uniformly so. Otherwise if all our stones are of varying levels of ‘non-flatness’, we would be hitting different spots with different stones and just get a mess or patchwork – wasting metal and stone and getting an inferior result.
A flat plane also constrains the surface a bit more than a convex or concave stone surface or just a random ‘wandering surface’ since after all any point on the surface of the stone must be no higher or lower than the two ends of the stone even if the surface isn’t perfectly parallel to the back surface of the stone. This will be discussed in detail later. The design of the WEPS also takes advantage of this property too as we will see in the next topic.
So to produce a flat surface you need a flat abrasive surface that doesn’t easily ;loose it’s flatness that can wear the stone down until a flat surface is produced on the stone. We will refer to an unflattened stone or stone needing flattening as being ‘dished’.
Stone wear patterns are relatively unique for hand sharpeners – almost like a signature. For a device like the WE, you will still have a signature pattern – still unique to each sharpener. Just as a diamond plate will wear unevenly, a stone will too. Typically you will not – and should not – sharpen to the very ends of the stone so you should expect the least wear on the ends of the stone or diamond plate. This will result in a concave surface on your stone. You also won’t wear the left and right side of the stone evenly, usually with the middle area highest but not always (individuals vary). Now if you let this go too far the sharpening angle will vary and you will get some degree of a convex rather than flat grind. This isn’t necessarily terrible, BUT if the next finer stone doesn’t have the same shape you get a different profile which is bad. The simplest solution is for all your stones to have the same shape, eg all equally warped. BUT the simplest shape to standardize on is a flat plane – zero warping.
Now a stone can have more wear in the center of the stone. How the hell would you do that? Well if you sharpen on the diagonal of a stone and alternate a diagonal going in the other direction you get an ‘X’ pattern. The overlap of the ‘X’ gets hit twice and wears fastest. So if you are just looking at the stone matching the flat surface, you will miss this and just see the outside flush with the lapping plate.
One of the simplest ways to correct this is to put horizontal and vertical lines on the stone with a pencil in a grid pattern – 3-4 strokes along the length and 5 or 6 across. Now as you lap the stone, you check for the remaining grid pattern. The area that remains of the grid is the DEEPEST part and you must remove stone to get EVERYTHING else ground down to that level. So you increase abrasion rates locally by pressing harder on the spots you want to grind fastest. That means pressure AROUND the deep spot, not on top of it.
So the typical wear pattern on a WE will be wear on the ends happening slowest. Some narrow knives won’t even use the ends of the stone on top. Most people won’t go all the way to the bottom either. This is EXPECTED and not at all unique to the WEPS but common among almost all types of sharpeners. The Pro model EdgePro tries to get around this with a ramp like device, but the cure is actually a worse solution and IMO should be disabled.
So typically you get a concave surface. So when you put the stone against the flat diamond lapping plate the two ends will touch and you get a gap in the middle. GENTLY abrade the stone surface applying pressure at the two ends of the stone. In time these two ends will come down to the level in the middle and you will get a flat surface. Just that simple. If the stone is bulging out in the middle, I tend to abrade the middle of the stone against the plate roughly perpendicular to the plate and gradually rotate the stone until it is parallel to the plate and all pencil lines are removed. In time you will need to use the pencil grid technique less and less.
It is best to do this a little at a time. It is best NOT to let a stone badly dish but just do fine adjustments or tuneups often. How often? This is a topic of endless debate. I prefer more often keeping stones more precisely flat. Similarly, I like to keep a knife sharp with minor tuneups rather than letting it get very dull and doing a major overhaul of the edge and walking around with a dull knife. If you do this with your finer grits, you can use a finer grit plate – 400 grit Atoma or DMT coarse or similar grit. If your stone is badly dished a 140 grit is preferred. For coarser stones a coarser grit is also preferred since this will give your stone more ‘bite’. For your finest stones you can – after achieving flatness – texturize or surface condition the stone for improved performance. Texturizing can be another subtopic.
People new to this will say ‘Why should I flatten so much – Isn’t this a colossal waste of stone?’ Actually no it isn’t. A badly dished stone wears fastest at its lowest points and the stone will eventually fail at these low points, leaving you with a badly deformed stone, and a lifetime of poorly shaped edges coming from that stone that prematurely fails.
To give a perspective on this a 5k Shapton stone properly flattened almost every time you use the stone will last you for YEARS.
How flat is flat? This too is a topic for debate with opinions varying from don’t worry about flatness to I It must be to a ten thousandth of an inch or some extreme. Remembering the phrase, ‘The enemy of good is perfect’ we need to strike a balance here. I’ll restrict my comments to synthetic stones here for now and expand on this topic for natural stones if anyone is interested.
So you can flatten against another stone. I find I prefer more precision than this. At the other extreme, you can flatten with a very high precision diamond platen like the Shapton diamond lapping plates or some industrial steel platens. In my opinion, it makes little sense to go to extremes of ultra precise flattening plates if you cannot precisely determine when your stone has reached the point of being as flat as the plate is capable of letting you be when flattening a stone. If you get a coarser stone flat to a ten thousandth of an inch and after a few strokes it is off by a couple thousandths, you are just playing around. Ultimately the issue of relative flatness is a personal judgement call and the removal of all the pencil marks is adequate enough IMO for all my sharpening needs – and I’m a very picky sharpener. I find the use of Atoma plates and DMT plates more than adequate for flattening duty.
Stone flattening should be done using water on a diamond plate. I prefer a plate equal or (better) larger than the stone itself. If you are using a similar sized stone you need to take care that the ends are getting abraded and that as the ends of the stone pass the plate that the stone stays flat to the whole plate.
When using water you generate ‘mud’ as the abraded stone combines with water. This mud will eventually clog the diamond plate making it less effective. This is easily remedied with a nail brush. A quick swipe or two quickly cleans out the impacted mud from between the diamonds and lets you continue to quickly remove stone until it is flat. There are uses for this mud so you don’t necessarily need to just discard it. Sometimes if you are just doing a minor amount of flattening, just leave the mud on the stone and it will give you more rapid abrasion of the steel. This sort of flattening can be accomplished in just a few seconds or a minute before using the stone for sharpening. There are other uses for mud – yet another future topic.
Now when you flatten a stone, especially when wet, the surface of the stone and the plate more and more precisely match, getting closer and closer. When it gets close enough, surface tension of the water comes into play as an ever stronger force and the plate can eventually BOND to the stone.
This is called STICTION. A flat continuous surface of diamonds can build up very strong stiction forces. If the diamonds are sufficiently coarse this is a less strong force. As the diamonds get finer stiction forces increase, so much so that the stone can stick to the plate making in near impossible to remove. Practically the DMT XXC or Atoma 140 have little stiction. A 400 Atoma also has little stiction but a DMT coarse of similar grit does have stiction issues. There are several solutions to this:
More water. This reduces the ability to squeeze out the water between the stone and the plate.
Less pressure
More speed. Keep things moving.
Don’t have a continuous surface. Here the Atoma plates excel, with clusters rather than a continuous surface. This allows you to use an even finer abrasive and because there is a gap between the diamonds stiction is GREATLY reduced letting one go up to the 1200 grit plates with little stiction issues.
Flattening stones is as much a part of sharpening as anything else relating to sharpening. It is a FUNDAMENTAL skill to acquire.
I’ve alluded to future topics of discussion and most likely have overlooked some other subtopics, so hopefully this initial posting will generate questions and alternative opinions or points of view. I haven’t discussed if you like to do circular flattening strokes or linear ones or strokes all in the same direction or cross patterns for instance (personally don’t feel it is important), but welcome alternative opinions on the topic.
Ken04/24/2012 at 5:47 pm #2902Thanks again, Ken! Very useful information now more and more stones are becoming available for the WEPS.
What I wonder is why synthetic stones (and natural stones) actually have to be flattened. Or, more precisely, why they degrade/break down. And how they do it. Nearly every stone seems different. Some synthetic stones require soaking and quite a lot of water and slurry to work effectively, some stones (like the Shaptons) require only a little bit of water and the WEPS stock ceramic stones also work dry (although I wonder sometimes whether a little bit of water would not help in keeping them clean). And they all wear down differently. The WEPS stock ceramic stones don’t seem to wear at all.
My guess would be that is has something to do with the bonds in which the abrasive particles are set, but that is about as far as I can guess.
04/25/2012 at 10:32 am #2905A great question, Mark! Here’s the tip of the iceberg
It’s not so much that synthetics wear down as much as the abrasives are released from the matrix in the spot on the stone that is used, causing the wear.
For example, the Chosera and Shapton stones for the WEPS generally wear in the middle because that is where you use them most, but not as much on the last 1-2cm of each end. The abrasive is aluminum oxide, which is still pretty hard – a 9+ on the Mohs scale. Rubbing the knife against the stone causes the abrasive to scratch, but there will always be a point where the abrasive either wears down, and/or is dislodged or pulled from the matrix.
The rate of abrasive wear is pretty much determined by the abrasive – Aluminum oxide is harder than your abrasives made from quartz, feldspar, or emery – which are about 5-7 on the Mohs. Diamonds wear the slowest, being a 10 on the Mohs scale. We’ll come back to this in a minute for the second part of your answer.
Stone wear is really the rate at which the abrasives are released, and is dependent on the matrix that holds the abrasive in place. The general rule is that softer stones release abrasive faster than harder stones, and coarser stones release abrasives faster than finer stones. The theory behind this to to simply add more abrasive particles into the mix on softer and coarser stones, making them faster. (There are added perks to stones dishing readily, such as creating a convex edge, but that’s another topic. We’ve seen how the concentration of abrasive can speed up or slow down sharpening/polishing on the pastes threads, too). So what happens here is the abrasive that is released does not necessarily break down, but the matrix holding it, does. As you get into the finer points of abrasives, you will find that natural stones’ abrasive do break down while synthetics tend not to, depending on the abrasive. For this discussion, let’s keep Aluminum Oxide as our synthetic abrasive since it is what the Shaptons and Choseras use, and the WEPS ceramic are probably something in the 9 Mohs range as well.
How porous a stone is also an indicator of how strongly the abrasives are held in place. More porous means more gaps between abrasives and binding agents, thus a faster abrasive releasing/wearing stone. Shaptons, for example, are not porous at all, so they hold the abrasives in place much longer, allowing for the fuller and more perfect scratch potential the aluminum oxide, which takes a while to wear down. IOW, less wear, more action, with no polish since there is little to no matrix breakdown.
Choseras, are what I consider to be slightly porous (compared to many other brands on the market), so they release abrasives at a slightly faster rate then Shaptons, but much slower than other brands. More importantly, the Choseras couple the abrasive release with the polishing effect of the binder breaking down, giving that amazing 10K polished mirror, but under the scope is slightly imperfect due to the inevitable release of the aluminum oxide abrasive particle here and there.
Getting back to the diamonds, since they wear the slowest of all abrasives, they are firmly embedded in a steel plate, with their multifaceted peaks sticking up. Because they wear so slowly, it would be an expensive waste to release them from the matrix, and is why diamonds tend to stay flatter longer – the height of the diamond is measured in microns rather than millimeters. (here’s[/url] a look at some diamond plates under the scope). They will still “wear” more in the middle than at the ends but the rate is almost imperceptible when you add the overall cutting speed. Any imperfections will easily be cut through at the next diamond plate level.
SO the bottom line here is that you need to lap stones to 1. flatten them. 2. Clean them 3. texture the surface (for abrasive release rate purposes).
04/25/2012 at 6:39 pm #2906Thanks a real lot Tom! This is very informative!
Do I understand it correctly if I summarize it as follows? (Which was my way of learning at school :).)
- Stones wear down because 1) the abrasive particles in the stones get worn down (i.e. shattered to pieces or at least scratched off) and because 2) they are released by the matrix bond.
- Effect 1) is the most important. The amount of wear depends on the hardness of the abrasive, so for example aluminium wears down faster than chromium that wears down faster than boron. (Just googled the Mohr scale <- very informative. Why do they use a different scale – the Rockwell scale – for steels?)
- Effect 2) depends on:
- the size of the abrasive particles: course stones wear faster than fine stones, probably because large particles get “hit out†easier
- the concentration of the abrasive particles: more particles means faster breakdown, probably because there is relatively less binding agent per particle
- the porousness of the stone, i.e. the gaps between abrasives and binding agents: more porous = larger gaps or more gaps = faster breakdown
- the strength of the binding agent: steel hardly releases abrasive particles (i.e. hardly wears down), whereas certain resins release the abrasive more easily.
- The breaking down of the binding agent (rather than the breaking down of abrasives) also causes a stone to polish, in addition to being abrasive. That is why the relative porous Choseras (compared to the Shaptons) polish so well at fine grit sizes.
[/ul]
And just trying to draw a conclusion to see whether I understand some things correctly: we can have diamond plates (a single layer – or at least not many layers) like the Wicked Edge diamond stones, comprising diamonds set in a steel plate, because the steel does not or hardly releases the diamonds and because the diamonds hardly wear. If we were to set aluminium oxide in a steel plate, the aluminium would wear down quickly and we were left with an almost clean steel plate. And if we were to set diamonds in a less strong resin, that would be pity of the diamonds that get released while still being intact.
Wow man, you guys are teaching us a real lot! :woohoo: We can even start to discuss which stones to use for which purposes! (I promise I won't do that – yet :).).
Very curious to your comments! This weekend my first Choseras will be deflorished :).
