What type of lubricant should be used?
I guess there should be a definite answer to this question as I’m sure many people will ask this into the future.
I was told by a bearing supplier that the version used by WE has a “nylon” race, so don’t use anything that can damage, swell, react, with nylon.
Don’t overheat the nylon via an oven etc.
Perhaps a product can be identified and approved for lubrication by WE.
Something mineral or oil based might cause problems by attracting grit or breaking down the nylon?
A dry lube graphite spray may be the best option, or teflon/silicone, not sure?
It would be great to get a determination here.
Thanks.
