Is the blade ready for stropping?
Recent › Forums › Main Forum › Stropping › Is the blade ready for stropping?
- This topic has 10 replies, 7 voices, and was last updated 07/13/2013 at 8:54 pm by
Phil Pasteur.
01/27/2013 at 2:46 am #9101
I just received my balsa strops and a set of split leather strops along with some HA diamond spray (0.25) and chromium oxide paste. I will be doing some experimenting this weekend, which is always enjoyable! I was just curious, what is the last stone you use before moving to the stropping phase. Please list the type of stone and the grit. What I would like to test is this, “at what point is stropping unproductive due to the blade being too coarse?”
01/27/2013 at 4:52 am #9103I use the WE diamond stones and 14/10 diamond paste on balsa strops and 5/3.5 diamond paste on leather strops. What I found, that works for me, is I sharpen with the 600 grit diamond stones and move up to 14 micron paste on balsa, then move back to the 800 grit diamond stones, then 10 micron paste on balsa, then I finish the edge on 1000 grit diamond stones. Once i’m happy with the edge I lower the angle by a degree or two and progress to polishing using the 5/3.5 diamond pastes on leather strops till i have a mirror polish. The wicked edge knife sharpener website has a detailed list of every stone and diamond paste/spray and images of scratch patterns under resources, labelled grit comparison chart. It helped me to determine the stone/grit sequence for sharpening.
p.s. I hope you have a microscope to help you test the effectiveness of stropping and when stropping is unproductive.
Happy sharpening
01/27/2013 at 5:25 am #9104I always start after my finest stone. Sometimes I quit after 1000 diamond, sometimes I go to 3k or 10k chosera.
Nicholas, I am interested in your progression. Do you find it works better alternating between the stones and balsa strops? Have you tried going to 1000 diamonds before stropping?
What difference do you see between the balsa and leather?
01/27/2013 at 8:31 am #9105Nearly any blade will benefit from stropping. But if you have a stone of a particular grit size, using the stone is usually more effective than stropping with a compound of an equivalent grit size. Unless you’re out for a special effect. So, as Geo said, strop after your finest stone. And then you have lots of options, but that’s another topic
Balsa and leather. The funny thing is that I see less of a difference than one might expect. In fact, with the WEPS pastes, I see very little difference. Leather still has a bit more stiction, but it is far less than one would probably expect. It does have an advantage over balsa in that it is able to blend a multi-beveled edge into a convex edge. However, with balsa you don’t run the risk of accidentally rounding your edge.
01/27/2013 at 10:36 am #9107I use the WE diamond stones and 14/10 diamond paste on balsa strops and 5/3.5 diamond paste on leather strops. What I found, that works for me, is I sharpen with the 600 grit diamond stones and move up to 14 micron paste on balsa, then move back to the 800 grit diamond stones, then 10 micron paste on balsa, then I finish the edge on 1000 grit diamond stones. Once i’m happy with the edge I lower the angle by a degree or two and progress to polishing using the 5/3.5 diamond pastes on leather strops till i have a mirror polish. The wicked edge knife sharpener website has a detailed list of every stone and diamond paste/spray and images of scratch patterns under resources, labelled grit comparison chart. It helped me to determine the stone/grit sequence for sharpening.
Nicholas,
This has come up many times on the WEPS boards. The common wisdom here, and advice I have given is to go through all of your stones and then strop. Looking at grit scratch patterns does not neccessarily tell you what is happening at the edge with different media. Give it a try and see what you think. The beauty of the WEPS is that you can easily experiment.Something to think about. Stropping will give a bit of a convex profile to the edge of the edge. Balsa less so than leather, but it still does it. When you switch back to a stone after stropping, you need to remove that convex shoulder before you get to the edge again. You are working against yourself by switching back and forth.
01/27/2013 at 8:07 pm #9118I only started my grit progression, as I described, a couple days ago. The results on (2)vg10 and (1)high carbon knives were insane and the best I have ever gotten, literally hair welding. I did baby the edge a lot, made consent contact with the blade, started a grit with little pressure and slowly removed all pressure as I finished with the grit, after 1000 grit I passed the leather strops over the blade once then proceeded to change the sharpening angle by one degree after a few passes. In the past I usually stropped after the highest stone or ceramic, but after reading up on scratch patterns of different grits I got to thinking of the best way to get a mirror polish…. anyways, that’s what I came up with and having the balsa strops is the only reason I attempted it. WEPS is a real beauty to experiment with:)
Phil, Thanks for the thought. Right back at you, just a thought, we’re going to strop anyways causing the bevel edges to convex anyways….. In the past I found I spent too much time stropping after the stone to obtain a mirror polish causing the bevel to convex and affect my edge. This saved me a lot of time and the polish was great, but I did baby it:)
Geo, Both balsa and leather are great, they both have great advantages over the other in specific things. Balsa is tougher and the leather is a great polisher. I’ll most likely always put 5 micron plus on balsa and anything under 5 micron on leather or any of the super fine strops. Anyways their both great:)
01/28/2013 at 8:28 am #9143Phil, Thanks for the thought. Right back at you, just a thought, we’re going to strop anyways causing the bevel edges to convex anyways….. In the past I found I spent too much time stropping after the stone to obtain a mirror polish causing the bevel to convex and affect my edge. This saved me a lot of time and the polish was great, but I did baby it
Nicholas,
I am a great proponent of doing what works for you. I never tend to argue with success. Still I would like to make some comments on this, from the logical point of view as well as my personal experience with the WEPS.First, if you spend too much time using strops to remove scratches, you need finer stones. The pastes and sprays that we use on our strops just do not have the abrasive concentration that stones do, meaning the are slower and less efficient at scratch removal. Depending on the scratch width and depth, it is not practical to get rid of them with strops. Typically stropping is used for final polish and edge refinement, not scratch removal. Of course there are exceptions. Ken Schwartz sell some sprays with 30 micron abrasives and more in them. With these abrasives on a hard media like nanocloth. perhaps scratch removal is more in reach.
Second, I am not sure if I communicated well about the different effects of the strops and stones and why they sort of cancel each other out when you alternate them. Consider that the stones in theory give you a nice V at the edge. The strops add a convex shoulder below the edge of the edge. When you go from stones to strops, you put the convex on the edge. When you go back to the stones, you must remove the convex shoulder before you get back to that perfect V. Now, this just does not seem very efficient. There must be a reason that folks that have lots of experience with the WEPS do not recommend this.
Third, If your are truly rounding your edge with the strops, you might examine your stropping technique. Try reducing the angle a bit, or reducing the number of strokes, or lightening up on the pressure. This will not get scratches removed, but, again, at this level you shoudn’t be trying to remove much in the way of scratches anyway.
Again, if what you are doing makes you happy, have at it. I am simply offering some of my experience… hard won at the expense of litteraly hundreds of hours sharpening on the WEPS. I have tried many, many different things. The way I use my WEPS now is way different than when I got it. However, I am still learning.
BTW One other thing to try as well… go through all of your stones and then strops, go back to something like the 1200 grit ceramics (or 1000 grit stones if that is what you heve) increase your angle by a degree or two and make a half dozen or so very light passes on the edge. If you have over stropped and rounded your edge, this should fix it. It also adds back some of the tooth and bite that stropping and/or the use of very fine stones removes.
01/28/2013 at 9:24 am #9145Cool, that’s wonderful to learn. Thank you.
I’ve had the WEPS for almost a year and my technique has also changed a lot since I first began sharpening. Getting onto the WEPS forum has made me think about and question my technique and process of sharpening on the wicked edge. Thank again Phil
07/12/2013 at 4:00 pm #13234BTW One other thing to try as well… go through all of your stones and then strops, go back to something like the 1200 grit ceramics (or 1000 grit stones if that is what you heve) increase your angle by a degree or two and make a half dozen or so very light passes on the edge. If you have over stropped and rounded your edge, this should fix it. It also adds back some of the tooth and bite that stropping and/or the use of very fine stones removes.
Phil, I just read your post above AFTER the question I just posted this morning about stropping that was linked to the post I just made on the Buck 450 recent sharpening………..I think you may have answered my question right here perfectly ! One question on this though……when you say to ” increase the angle by a degree “, should I do that by sliding the arms out on the angle rod, or should I use the micro-fine adjustment screw on the arms, and if so, what would a degree be on that adjustment screw, a full 360 turn or what ? ( as it is hard to use the angle cube and measure a single degree…..at least in my rather limited experience ) Thanks for any help for this newb trying to learn all he can ! :woohoo:
07/13/2013 at 9:44 am #13251BTW One other thing to try as well… go through all of your stones and then strops, go back to something like the 1200 grit ceramics (or 1000 grit stones if that is what you heve) increase your angle by a degree or two and make a half dozen or so very light passes on the edge. If you have over stropped and rounded your edge, this should fix it. It also adds back some of the tooth and bite that stropping and/or the use of very fine stones removes.
Phil, I just read your post above AFTER the question I just posted this morning about stropping that was linked to the post I just made on the Buck 450 recent sharpening………..I think you may have answered my question right here perfectly ! One question on this though……when you say to ” increase the angle by a degree “, should I do that by sliding the arms out on the angle rod, or should I use the micro-fine adjustment screw on the arms, and if so, what would a degree be on that adjustment screw, a full 360 turn or what ? ( as it is hard to use the angle cube and measure a single degree…..at least in my rather limited experience ) Thanks for any help for this newb trying to learn all he can ! :woohoo:[/quote]
Darrell, What works for me is when I am ready to change my angle, I put my cube up against the paddle with the opposite hand that will be turning the hex wrench on the micro adjustment. Now holding the cube in place on the strops is tricky at first. I use my thumb and middle finger to bridge the paddle and cube. My index finger to pull back on the cube and my ring and pinky tuck behind the strop.
This allows me to make turns with my wrench and after making an adjustment lift up on strop/paddle and set it back down to let the cube reset. I know this is kind of tricky at first? Doing this will allow me to make fine adjustments using the cube to get a reading. The cube can actually take several seconds (seven seconds to be exact. From a different thread) to stabilize. Sometimes I will get lucky and it happens and a turn or two, sometimes it can take many adjustments but you can get it right on the money!
This way you can get exactly what your looking for weather it be a degree and a half or just .10.
I have tried the various ways of adjusting the strops and for me I like to match what I have been using with the stone and a very light (feather touch) stroke. I find that I can make hair pop of the blade doing this. It was endless fun when I first learned how to do it!! :woohoo: :silly: :ohmy:
I hope this helps as Phil may or may not catch this as it is an old thread? You can always send him a PM if I have not answered your question? Good luck this should get you down to a nats ass!07/13/2013 at 8:54 pm #13270Phil, I just read your post above AFTER the question I just posted this morning about stropping that was linked to the post I just made on the Buck 450 recent sharpening………..I think you may have answered my question right here perfectly ! One question on this though……when you say to ” increase the angle by a degree “, should I do that by sliding the arms out on the angle rod, or should I use the micro-fine adjustment screw on the arms, and if so, what would a degree be on that adjustment screw, a full 360 turn or what ? ( as it is hard to use the angle cube and measure a single degree…..at least in my rather limited experience ) Thanks for any help for this newb trying to learn all he can ! :woohoo:
Darrell,
Do you have an angle cube? I use that device t set the angles. I guess it does not matter which method you use to change the angle. Of course the micro adjustments are easier to work with. Typically I start the setup with the micro adjustments centered in their travel so I have the max +/- adjustment available. I change angles of a degree or more using the adjustments made by moving the slider on the base bar. I don’t think there would be anything wrong with leaving the slider in place and calibrating the amount or turns of the micro adjustments required to get your desired amount of angle change. I would have to check, but I don’t think I get a full degree in either direction on the micro adjustments from their centered position.The amount that you decrease the angle is really dependent on your stropping technique as well. If you, like Eamon, (and myself) use very light strokes, you may get away with a half degree decrease in angle. OTH, if you are stropping as Clay has described, with alcohol on the strops and lifting the base up with each stroke, you may want to decrease the angle by 2 degrees or more. The thing that you are trying to do is to finesse and refine the edge without rounding it. This becomes a balancing act of sorts. The key, after you understand the concept, is to try some different things and see what is working for you. My feather light is not likely identical to the pressure you would describe with the same term. As it is the interaction between the compliance of the stropping substrate, the amount of pressure used, and the angle, it would be difficult to set any sort of absolute rules for this.
Keep in mind the material compliance or give. The change in angle would be slightly different for leather versus balsa, or Kangaroo. Respectively they would require a descending amount of angle change. With nanocloth strops, I don’t change the angle from my primary angle at all.
I hope that this helps!
