Its a shame you did not stop here before your purchase. You could have bought the field kit, with a ” C ” clamp which would allow you to clamp your W.E to any surface. Personally, I like the flexibility of being able to turn my base to view the edge from different angles.. You may want to purchase a “C” clamp
At a hardware supply store. this will allow you to take your unit anywhere and clamp it to surfaces of different thicknesses.
here is the field kit… the same price as the basic system, but you can see a C clamp will do the job. you are going to have to measure exactly what you need when you get it, to include washers… the system does not come with mounting hardware for your mounting table.
Your Basic unit will not have the clamp adapter, but you can add some protective tape you your base and clamp it. it does not take much clamping force to overcome the stroke pressure necessary to sharpen a knife…
Good Luck
Bill aka ET
