Here’s a Trick Question for you…
Recent Forums Main Forum Knife Photos Here’s a Trick Question for you…
  • #3256
    BassLake Dan
    • Topics: 11
    Things are getting a little slow around my neck of the woods so I thought I would have some brain teaser fun with all you experts out there.
    Who can figure out this blade? What is it? How many bevels does it have, and how was the edge finished on each of those bevels? Let’s ask this another way: If you were to set this progression up to duplicate this on your WEPs what would the specs be for it, i.e angles /grits /stones/ laps / etc… ???
    #3263
    Joyal Taylor
    • Topics: 9
    I’ll give it a go.
    The magnification is 200x
    2 bevels with coarse diamond stones.
    What, at first, looks like a third micro bevel is actually black magic marker that was added after sharpening.
    Primary bevel at 20 degrees with 100 diamond
    Secondary bevel at 25 degrees with 400 diamond
    No stropping
    Knife is a Walmart kitchen knife.
    #3267
    I agree with Holymolar. He is spot on. He just made a mistake in identifying the knife. It’s an IKEA chef’s knife.
    #3271
    Tony Pettersen
    • Topics: 4
    Burn the witch! :blink: :ohmy:
    i totally dident see the marker.. thats just good!
    #3274
    BassLake Dan
    • Topics: 11
    OK,.. Time for a HINT:
    Holymolar was very observant about the Black Line. He was RIGHT it is a BLACK Line, but it *was not* made with a Sharpie Marker. The hint is that (read very carefully here–>>) the marking material was *applied* another way, not by a Sharpie…
    #3277
    Joyal Taylor
    • Topics: 9
    Does your wife know that you used her mascara to put that black line on the edge?
    I’m telling.
    LOL
    #3417
    BassLake Dan
    • Topics: 11
    Well, it’s been 1 week, and no one has really gotten close, or even tried to guess, so I will end the teaser now:
    The Black line is a coating of PVD (vapor deposited) Boron Carbide, and the blade is an off the shelf item from Rite-Aid Pharmacy, it is a Double Edged Razor Blade… For those of you that are interested the BC coating provides increased edge life and lubricity.
    #3418
    That’s interesting! How do you apply this boron carbide? And does result in better edge retention? And doesn’t it make the edge duller? (It probably makes the edge thicker, but if that is only a few molecules, you probably won’t notice.)
    #3421
    BassLake Dan
    • Topics: 11
    You can’t make that work at home, unfortunately.. it is a either lab / or industrial process. Requires equipment that is not usually found in the average garage or work shop. There are, however, coatings that you can apply at home that contain teflon and molybdenum disulfide, They are epoxy paint based, and would probably have very limited life on a blade, but it might be a fun hobby project to experiment with.. Try this source to get yourself a test can of the stuff..
