Balsa Wood – Different Grades?
Recent › Forums › Main Forum › Stropping › Balsa Wood – Different Grades?
- This topic has 12 replies, 5 voices, and was last updated 03/31/2015 at 11:04 pm by
Steven N. Bolin.
03/30/2015 at 5:51 pm #24794
I was at a local hobby shop a week or so ago and ran across a whole rack of various size balsa wood (I’m assuming for building RC planes). They carry balsa that’ll fit on a pair of blanks and I almost bought some just to play with… After a bit of quality control and sanding at high grits to ensure a somewhat uniform porous surface that’ll hold compound wouldn’t it get the job done?
I hear you guys talking about various grades… Can someone enlighten me?
03/30/2015 at 5:57 pm #24795I’m sure Eric (Zamfir) will be by in a bit to educate
They all get the job done, I just didn’t really like the really soft stuff because it would dish, but if you use it on the finer grits and light pressure you will be fine and it feels really nice.
03/30/2015 at 7:27 pm #24798I’m sure Eric (Zamfir) will be by in a bit to educate
Awesome, thanks Josh! I might have to make a pit stop later and pick some up.
Oh, and ,before I forget! I was anticipating your feedback on that MAJOR repair I did on my buddy’s Miyabi.
2 videos here – 1st is me finishing up thinning behind behind the edge/prepping for brand new edge. 2nd is me finishing up the actual cutting edge itself in the WEPS.
Check it out paleeeeeez?! Gotta have that RazorEdge feedback, bro. Otherwise, I can’t sleep well at night.
03/30/2015 at 7:28 pm #24799http://www.rcscalebuilder.com/tutorials/balsa/balsa_1.htm
http://www.specializedbalsa.com/products/balsa_sticks.phpHere’s some info. I wasn’t impressed with the balsa that I bought from the store and made strops from. It compressed and dished so I went back to leather. I might order some high density an try it out again but I’m pretty much set with my leather
03/30/2015 at 8:14 pm #24800Dan, both you and Josh mentioned dishing.
Ok… So… What about compressing the you know what outta the stuff? Immediately after reading your reply something came to mind – Putting it in between 2 steel flat bars, throwing it a vise, gradually increasing the force over a few hours until the desired thickness is reached, then leaving it for 24 hours or so. Then, after removing it from the vise, sanding down the surface so that it’s porous again and ready to take the compound.
… Yeah?
I mean, heck, the place to pick some up is only couple miles away from my apartment. Give me the go-ahead, I’ll go grab some right now and give it a shot if you guys think this is even an option worth trying!
03/30/2015 at 9:29 pm #24805If you have nothing to do then go ahead man. The stuff is cheap and easy to cut. They also have basswood which I’ve used too. Why not try something new?
03/31/2015 at 7:00 am #24822If you have nothing to do then go ahead man. The stuff is cheap and easy to cut. They also have basswood which I’ve used too. Why not try something new?
Exactly… just make sure to report back! hehe
03/31/2015 at 8:49 pm #24827I ordered 4 different densities of balsa, light, medium, heavy, and extra heavy. I cut them to the wicked edge paddle size and sent 2 sets of each to Clay for testing. I also sent a set of all 4 to Josh for testing.
This was all talked about in this thread before:
https://knife.wickededgeusa.com/forum/2-welcome-mat/13334-cool-idea-strop-handles?limitstart=0&start=10You don’t read yer own threads? goof ball…you already knew this.. :silly:
03/31/2015 at 8:52 pm #24829Has anyone ever tried stropping with good old soft pine wood? I can picture super light balsa dishing out under medium or greater pressure but not sure how denser balsa would compare to pine.
03/31/2015 at 8:54 pm #24830denser Balsa is very close to pine..maybe even harder
03/31/2015 at 9:00 pm #24831You don’t read yer own threads? goof ball…you already knew this.. :silly:
Bahahaha. Yeah, man, as soon as the thread got hijacked I stopped. Not because I didn’t care, but because I couldn’t go down that rabbit hole quite yet… So much to keep up with…You guys are scraping trees, I’ve still got my spots
03/31/2015 at 9:25 pm #24833Has anyone ever tried stropping with good old soft pine wood? I can picture super light balsa dishing out under medium or greater pressure but not sure how denser balsa would compare to pine.
I definitely have not had any dishing issues w/ my extra heavy for sure, or my heavy for that matter that i have seen, and i have been checking…
03/31/2015 at 11:04 pm #24840UPDATE: I picked up a variety pack of balsa for $8.99 from the hobby shop. The densest pieces are the thickest, which are about 1/2″ or so. All others are too soft given my “finger dent” test. I’ll cut the 1/2″ to size and sand down the faces to the appropriate thickness. This will be the first time I’ve used balsa and it’s a perfect opportunity to try em on my 940 I reprofiled at 17dps last night!
NOTE: I also picked up a strip of bass wood while I was there. Curious to play with it as well.
