Angles less than 15 degrees?
Recent Forums Main Forum Welcome Mat Angles less than 15 degrees?
  • #25050
    Kenneth Krone
    I was watching a video that Clay made about 2011 using a gen 1(?) setup where he was sharpening a Shun nakiri knife that had a primary bevel of 11 degrees that came to an edge of 16 degrees
    I have a gen 1, I think, and mine only can do a 15 degree bevel. The video doesn’t show any extension device to raise the knife higher–how does he achieve the 11 degree bevel with that equipment?
    Thanks
    KK
    #25051
    Thanks
    KK
    KK,
    I just clamped the knife as high up in the clamp as I could and then moved the collar in as tight as possible without letting the stones contact the vise. I then verified the angle with the Angle Cube. The nakiri is very wide from spine to edge which is what allowed me to hit so low an angle.
    –Clay
    #25056
    KK, ,also keep in mind that the degree bar is calibrated to be correct when the knife edge is 5/8″ off of the top of the vise if I remember correctly. If you have a wide blade then the knife edge will be much higher and allow a lower angle. Hope this helps.
    #25062
    Kenneth Krone
    Thanks, Clay and Josh. I did not know the height above the clamp at which the angle was calculated–that is most helpful to know.
    Love the system, Clay. I have used it for a number of years for my kitchen knives and it is a real treat to so easily keep them sharp.
    #25087
    Steven N. Bolin
    • Topics: 47
    From what I understand, you really only need about 1/8″ of real estate at the spine to successfully clamp a knife.
    Just be careful since the higher up you go, the fulcrum moves closer to the top of the jaws where there’s less material to take the stress. Clamping too tight at this point increases the likelihood of bending the right/movable side of the jaws
    #25088
    Kenneth Krone
    Thanks for the reminder! That would be an expensive price to pay!
    #25090
    Steven N. Bolin
    • Topics: 47
    Luckily it’s covered under warranty 😉
